Before creating the topic
- Search forum for similar topics
- Check http://docs.blynk.cc and http://help.blynk.cc/
- Add details :
• Blynk Library version
• Add your sketch code.Code should be formatted as example below.
I am using WEMOS D1 R1.
Have been trying for hours but nothing works.
char auth[] = "2cafade5c1224e2d8232af56667925ed";
char ssid[] = "Asif PTCL";
char pass[] = "asif1914";
BLYNK_WRITE(v0)
int up = param.asInt();
Blynk.virtualWrite(V4, 1);
BLYNK_WRITE(v1)
int down = param.asInt();
Blynk.virtualWrite(V4, 2);
BLYNK_WRITE(v2)
int turnLeft = param.asInt();
Blynk.virtualWrite(V4, 3);
BLYNK_WRITE(v3)
int turnRight = param.asInt();
Blynk.virtualWrite(V4, 4);
