char auth[] = "";
char ssid[] = "";
char pass[] = "";
// in Blynk app writes values to the Virtual Pin 1
BLYNK_WRITE(V1)
// You can also use:
// String i = param.asStr();
// double d = param.asDouble();
Serial.print("V1 Slider value is: ");
Serial.println(pinValue);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
Everything should be good, but when I move the slider attached to V1, nothing appears in the serial monitor. I have made sure that the app is running and the slider is attached to the NodeMCU device.
If anyone has any insight as to what’s going on here, it would greatly be appreciated. Thanks!
I double checked and that device has the correct auth token as I was using. Just to be sure I refreshed the token and put the new one in the sketch, but still nothing.
char auth[] = "ZcEh0pYCJTMMn9mng_47os1GojpyY8W0";
char ssid[] = "";
char pass[] = "";
BLYNK_WRITE(V1)
I’d suggest that you delete the project from the app and add a single new device and one widget attached to V1. Use the new Auth token 8n your sketch and see if it works.
