I making a project on esp32 in arduino where i want to control diode on two mode by wifi. first mode
where i just on/off it by button (on virtual pin V1) - BLYNK_WRITE(V1)
and second mode where i control brightness by slider but , I want to in second mode so that the slider control is possible when I activate the button that allows it . - BLYNK_WTRITE(V2)
If someone could help me with that I wolud be very greatful
#define BLYNK_TEMPLATE_ID "TMPLxxxxxx"
#define BLYNK_DEVICE_NAME "Device"
#define BLYNK_AUTH_TOKEN "YourAuthToken"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char pass[] = "YourPassword";
Blynk_Write(V1) // first mode where i just switch on/off diode
int pinValue = param.asInt()'
digital(13, pinValue);
BLYNK_WRITE(V2) // here is a second mode where i control brightness by slider
// i don't know how to add button so that the slider can only be controlled when is pressed a button
analogWrite(D1,pinValue);
Blynk.virtualWrite(V1, pinValue); // by this line i see on gauge how bright it's
Serial.print("V0 Slider value is: ");
Serial.println(pinValue);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// to avoid delay() function!
I’ ll be very greatful if someone could help me with that.
~ fil
