On testing a new setup it turned out to be not working so I delved into it. After a while I noticed that the writes to my ‘central’ ESP (that processes all communication) got a massive amount of updates over BLYNK_WRITE_DEFAULT. Hence I disconnected ALL ESP including the blynk app and then just ran the central device clean with this code:
BLYNK_WRITE_DEFAULT(){
//all pins used consist out of 2 digits
int pin = request.pin;
int one = pin % 10; //this tells the type of operation
int ten = pin/10 % 10 - 1; //this tells which device it came from (V10 = 1-1 = LIVING = 0)
Serial.println("");
Serial.print("Incomming value: ");
Serial.print(request.pin);
Serial.print("/ OPERATION:");
Serial.print(one);
Serial.print("/ DEVICE:");
Serial.println(ten);
So the serial monitor should not process anything, right?
This is what I got: (I let it run for about 2 seconds after connection)
EPS Name: ESP_CENTRAL
OTA Ready
IP address: 192.168.1.111
Starting 'alive' routine...
Incomming value: 10/ OPERATION:0/ DEVICE:0
Incomming value: 16/ OPERATION:6/ DEVICE:0
Incomming value: 13/ OPERATION:3/ DEVICE:0
Incomming value: 14/ OPERATION:4/ DEVICE:0
Incomming value: 12/ OPERATION:2/ DEVICE:0
Incomming value: 17/ OPERATION:7/ DEVICE:0
Incomming value: 15/ OPERATION:5/ DEVICE:0
Incomming value: 11/ OPERATION:1/ DEVICE:0
Incomming value: 18/ OPERATION:8/ DEVICE:0
Incomming value: 47/ OPERATION:7/ DEVICE:3
Incomming value: 77/ OPERATION:7/ DEVICE:6
Incomming value: 45/ OPERATION:5/ DEVICE:3
Incomming value: 76/ OPERATION:6/ DEVICE:6
Incomming value: 71/ OPERATION:1/ DEVICE:6
Incomming value: 37/ OPERATION:7/ DEVICE:2
Incomming value: 67/ OPERATION:7/ DEVICE:5
Incomming value: 35/ OPERATION:5/ DEVICE:2
Incomming value: 0/ OPERATION:0/ DEVICE:-1
Incomming value: 27/ OPERATION:7/ DEVICE:1
Incomming value: 57/ OPERATION:7/ DEVICE:4
Incomming value: 25/ OPERATION:5/ DEVICE:1
Incomming value: 30/ OPERATION:0/ DEVICE:2
Incomming value: 38/ OPERATION:8/ DEVICE:2
Incomming value: 31/ OPERATION:1/ DEVICE:2
Incomming value: 33/ OPERATION:3/ DEVICE:2
Incomming value: 32/ OPERATION:2/ DEVICE:2
Incomming value: 50/ OPERATION:0/ DEVICE:4
Incomming value: 58/ OPERATION:8/ DEVICE:4
Incomming value: 51/ OPERATION:1/ DEVICE:4
Incomming value: 53/ OPERATION:3/ DEVICE:4
Incomming value: 52/ OPERATION:2/ DEVICE:4
Incomming value: 60/ OPERATION:0/ DEVICE:5
Incomming value: 68/ OPERATION:8/ DEVICE:5
Incomming value: 61/ OPERATION:1/ DEVICE:5
Incomming value: 63/ OPERATION:3/ DEVICE:5
Incomming value: 62/ OPERATION:2/ DEVICE:5
Incomming value: 70/ OPERATION:0/ DEVICE:6
Incomming value: 78/ OPERATION:8/ DEVICE:6
