Hi Blynkers,
having run quite some projects with Blynk (and also Google Home via IFTTT) I now wanted to integrate all my home automation devices into a common user interface and bring things back to the intranet (with a local Blynk server). OpenHab2 seems to be a pretty good framework to do this and expose only one channel to the outside world.
However, when I started with first steps I could not get my head around addressing Blynk via OpenHab2. It seems that it is almost too flexible, I could use cURL, Python oder Java. I am confused what would be the best way (e.g., http binding, exec binding)
Has anybody in this group worked with OpenHab2 and can share the approach and an example?
Thanks a ton,
Matthias
