Hi, i try to test nodemcu with DHT11 sensor. I connect the sensor in pin 4 (that’s mean pin 2 for the arduino) and test the example only with DHT. Working perfect!!! After try the example from Blynk examples sites with nodemcua and DHT11 and everything working fine except the temperature & humidity results (Failed to read from DHT sensor!). What is wrong with this?
http://twitter.com/blynk_app
This example shows how value can be pushed from Arduino to
the Blynk App.
WARNING :
For this example you'll need Adafruit DHT sensor libraries:
https://github.com/adafruit/Adafruit_Sensor
https://github.com/adafruit/DHT-sensor-library
App project setup:
Value Display widget attached to V5
Value Display widget attached to V6
#include <DHT.h>
char auth[] = "XXXXXXXXXXXXXXXXXXXX";
char ssid[] = "XXXXXXXXX";
char pass[] = "XXXXXXXX";
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
dht.begin();
