Blynk with Ethernet shield - HanRun. HR911105A 16/32 + Arduino Uno
Ah, well you did say shield :wink:
Just be aware that the sticker on the socket is referring to the socket’s part number (followed by stock or date code?), not the actual device (lazy marketing). The number you want to know is the one on the chip. That said, it is probably still compatible with the links I sent you.
The Jacar link you provided does have a data sheet that shows how to hook it up to a Duinotech (AKA Arduino clone) and appears to be the same wiring as the shield, minus the CD card, So just wire it up and try those other links I provided for operation.
NOTE The data pins should be 5v compliant, but the unit itself is 3.3v.
