I executed sample code for cc3200 with Blynk Application.I want to use same application in Code Composer studio , I know how to connect to server and how to send data to server or in which format I need to send .
I want to send sensor data to Bylnk server using TCP/IP in code composer studio without using Energia sketch.I don’t know in which format I need to send data(sensor data) to Bylnk server. If anyone knows please help me.
I can see you are interested in Blynk with Cose Composer Studio.
I want to develop an application but I only find examples with Energia. Could you share your code so I could have an starting point? Thank you.
just tried to run your code as is simply changing token with mine .
sendCmd always fails at the first sl_Send .
Do you have any updated version to share ?
Thank you,
Paolo
