I use Arduino UNO + Etherner Shield W5100 with this code.
#define BLYNK_PRINT Serial #include <SPI.h> #include <Ethernet.h> #include <BlynkSimpleEthernet.h> #include "DHT.h" #include "ThingSpeak.h" #define DHTPIN 6 #define DHTTYPE DHT11 DHT dht(DHTPIN, DHTTYPE); unsigned long myChannelNumber = xxxxxxxxxxx; const char * myWriteAPIKey = "xxxxxxxxxxxxxxx"; char auth[] = "xxxxxxxxxxx"; BlynkTimer timer; // Announcing the timer EthernetClient client; void sensorToBlynk() { float h = dht.readHumidity(); float t = dht.readTemperature(); Blynk.virtualWrite(V0, t); Blynk.virtualWrite(V1, h); Serial.print("Humidity: "); Serial.print(h); Serial.print(" %\t"); Serial.print("Temperature: "); Serial.print(t); Serial.print(" *C "); Serial.println(); } void sensorToThingspeak() { float h = dht.readHumidity(); float t = dht.readTemperature(); ThingSpeak.setField(1, t); ThingSpeak.setField(2, h); // write to the ThingSpeak channel int x = ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey); if(x == 200){ Serial.println("Channel update successful."); } else{ Serial.println("Problem updating channel. HTTP error code " + String(x)); } } void setup() { Serial.begin(115200); dht.begin(); Blynk.begin(auth, "xxxxxxxx.com", 8080); timer.setInterval(3000L, sensorToBlynk); //timer will run every sec timer.setInterval(600000L, sensorToThingspeak); } void loop() { Blynk.run(); timer.run(); }
It show output like this.
[538932] Connecting to xxxxxxxx.com:8080
[539091] Ready (ping: 2ms).
Humidity: 57.00 % Temperature: 26.10 *C
[557164] Connecting to xxxxxxxx.com:8080
[562165] Connecting to :8080
[562225] Ready (ping: 2ms).
Itโs reconnect every 5 second ? How to fix it ?
