Blynk wih IFTTT problem
hi everyone i try to use the IFTTT with my Blynk but it not work
here is my config for IFTTT
i try with http://blynk-cloud.com/2c799def5b4xxxxxxxxxxxxxxxxxxxxxxx/update/D18?value=0 it’s work prefect. Please help me. Thank you
So why not use that as the URL in IFTTT? You have something completely different.
Or better yet use the BLYNK HTTP to create the needed URL.
Plus the method should be GET
i try with this but it not work…
Content Type should be application/json
Well at least those are the settings I use for IFTTT.
Hello
please look how i made it so it works with alexa
@hoangthaibmv You should get the ip address blynk-cloud.com resolves for your browser and use the ip address and not the hostname. Reason is that GeoDNS gives different ip addresses based on geographic region. IFTTT resolves from the US which may yield/connect to the ip your URL in the browser resolves to.
