Blynk + Wifimanager + DoubleResetDetector
I read all topics for these them but i still have problem with conection to Blynk.
I want put Toro_blanco tip in my sketch but app is working without Blynk connection
Beter question: How to integrate DoubleResetDetektor in these skech to all work.
Help please…
#include <FS.h>                   //this needs to be first, or it all crashes and burns...
/* ESP & Blynk & Spiffs*/
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>          //https://github.com/tzapu/WiFiManager
#include <ArduinoJson.h>          //https://github.com/bblanchon/ArduinoJson
//char auth[] = "xxxx";
char blynk_token[34] = "my auth";
//flag for saving data
bool shouldSaveConfig = false;
//callback notifying us of the need to save config
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
#define BUZZER D8 // D8 =  U ovaj PIN ide zvbučnik
unsigned long time_now = 0; //V3 pauziranje zvuka
int period = 5000; //V3 U milisekundama
#pragma region Globals
unsigned int notified = 0; //dodano u V4 za potrebe maila
#pragma endregion Globals
//dupli klik na reset za konfiguraciju
#include <WiFiManager.h>          //https://github.com/kentaylor/WiFiManager
#include <DoubleResetDetector.h>  //https://github.com/datacute/DoubleResetDetector
// Number of seconds after reset during which a
// subseqent reset will be considered a double reset.
#define DRD_TIMEOUT 10
// RTC Memory Address for the DoubleResetDetector to use
#define DRD_ADDRESS 0
DoubleResetDetector drd(DRD_TIMEOUT, DRD_ADDRESS);
// Onboard LED I/O pin on NodeMCU board
const int PIN_LED = 2; // D4 on NodeMCU and WeMos. Controls the onboard LED.
// Indicates whether ESP has WiFi credentials saved from previous session, or double reset detected
bool initialConfig = false;
/* TIMER */
/* DS18B20 Temperature Sensor */
#include <OneWire.h>
#include<DallasTemperature.h>
#define ONE_WIRE_BUS 2 // DS18B20 on arduino pin2 corresponds to D4 on physical board
DallasTemperature DS18B20(&oneWire);
int temp_0;
int temp_1;
 Serial.println("\n Starting");
 //clean FS, for testing
  //SPIFFS.format();
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(blynk_token, json["blynk_token"]);
          Serial.println("failed to load json config");
    Serial.println("failed to mount FS");
  //end read
  WiFi.printDiag(Serial); //Remove this line if you do not want to see WiFi password printed
  if (WiFi.SSID()==""){
    Serial.println("We haven't got any access point credentials, so get them now");
    initialConfig = true;
  if (drd.detectDoubleReset()) {
    Serial.println("Double Reset Detected");
  if (initialConfig) {
    Serial.println("Starting configuration portal.");
    digitalWrite(PIN_LED, LOW); // turn the LED on by making the voltage LOW to tell us we are in configuration mode.
    //Local intialization. Once its business is done, there is no need to keep it around
    WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 33);
  //WiFiManager
  WiFiManager wifiManager;
  //set config save notify callback
  wifiManager.setSaveConfigCallback(saveConfigCallback);
   //add all your parameters here
  wifiManager.addParameter(&custom_blynk_token);
 //fetches ssid and pass and tries to connect
  //if it does not connect it starts an access point with the specified name
  //here  "AutoConnectAP"
  //and goes into a blocking loop awaiting configuration
  if (!wifiManager.autoConnect("Wifi_Manager", "password")) {
    Serial.println("failed to connect and hit timeout");
    delay(3000);
    //reset and try again, or maybe put it to deep sleep
    ESP.reset();
    delay(5000);
  Serial.println("connected...yeey :)");
  //read updated parameters
  strcpy(blynk_token, custom_blynk_token.getValue());
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    json["blynk_token"] = blynk_token;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.printTo(configFile);
    configFile.close();
    //end save
  //Serial.println("local ip");
  //Serial.println(WiFi.localIP());
  Blynk.config(blynk_token);
  bool result = Blynk.connect();
if (result != true)
  Serial.println("BLYNK Connection Fail");
  Serial.println(blynk_token);
  wifiManager.resetSettings();
  ESP.reset();
  delay (5000);
  Serial.println("BLYNK Connected");
    digitalWrite(PIN_LED, HIGH); // Turn led off as we are not in configuration mode.
    ESP.reset(); // This is a bit crude. For some unknown reason webserver can only be started once per boot up
    // so resetting the device allows to go back into config mode again when it reboots.
    delay(5000);
  WiFi.mode(WIFI_STA); // Force to station mode because if device was switched off while in access point mode it will start up next time in access point mode.
  unsigned long startedAt = millis();
  Serial.print("After waiting ");
  int connRes = WiFi.waitForConnectResult();
  float waited = (millis()- startedAt);
  Serial.print(waited/1000);
  Serial.print(" secs in setup() connection result is ");
  Serial.println(connRes);
  if (WiFi.status()!=WL_CONNECTED){
    Serial.println("failed to connect, finishing setup anyway");
  } else{
    Serial.print("local ip: ");
 //Blynk.begin(auth, ssid, pass);
  DS18B20.begin();
  timer.setInterval(10000L, getSendData);
  Serial.println(" ");
  Serial.println("Testing Dual Sensor data");
  pinMode(BUZZER, OUTPUT);  //dodano u V3
  if (temp_0 >= 70){
          if(millis() > time_now + period){
        time_now = millis();
        tone(BUZZER, 2000, 1000); // dodano u V3
        Serial.println("Biiiiip");
 * Send Sensor data to Blynk i uključi alarm kod visoke temperature
void getSendData()
  DS18B20.requestTemperatures();
  temp_0 = DS18B20.getTempCByIndex(0); // Sensor 0 will capture Temp in Celzius
  temp_1 = DS18B20.getTempCByIndex(1); // Sensor 1 will capture Temp in Celzius
 if (temp_0 >= 70 && notified == 0){ // check to see if flag is also set - dodaj temperaturu slanja maila
  notified = 1;
  Blynk.email("zeljko@fegi.net", "ALARM", "Temperatura je iznad 70");
  Serial.print("Email Sent");
} else if(temp_0 < 65){ // histereza ponovnog uključivanja slanja maila
  notified = 0;
  Serial.print("Temp_0: ");
  Serial.print(temp_0);
  Serial.print(" oC . Temp_1: ");
  Serial.print(temp_1);
  Serial.println(" oC");
  Blynk.virtualWrite(V10, temp_0); //virtual pin V10
  Blynk.virtualWrite(V11, temp_1); //virtual pin V11
