Blynk Motion Sensor Security Camera with Notification
Hey, here I am writing this topic for resolving my project errors.
I have successfully created the circuit and uploaded the code properly. But blynk is showing “Project wasn’t online yet error”.
The serial monitor output (via your FTDI board) will give you some clues about why you’re experiencing this issue.
You are using the Legacy app, and if you’re using the Legacy cloud servers then they will be de-commissioned at the end of this month.
If you’re using a legacy local server then your issue may relate to how you’ve changed the. Example sketch to work with your local server, or how you’ve configured your local server.
