Put 3 backticks on a line (Google the word if you are unsure what they are).
Paste your sketch on a new line after the backticks
After the sketch on a new line enter 3 more backticks.
Hello, thank you for your reply. I m not using a temperature sensor. temperature data is obtained from Wunderground weather service. When I comment the line 202 out then I get the right temperature reported by Weatherunderground in my serial monitor without problems.
The MIT License (MIT)
Copyright (c) 2015 by bbx10node@gmail.com
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
#ifndef min
#define min(x,y) (((x)<(y))?(x):(y))
#endif
#ifndef max
#define max(x,y) (((x)>(y))?(x):(y))
#endif
#include <ArduinoJson.h>
char auth[] = "xxxxxxxx";
char ssid[] = "xxxxxxxxxx";
char pass[] = "xxxxxx";
// Use your own API key by signing up for a free developer account.
// http://www.wunderground.com/weather/api/
#define WU_API_KEY "xxxxxxxx"
// Specify your favorite location one of these ways.
//#define WU_LOCATION "CA/HOLLYWOOD"
// US ZIP code
//#define WU_LOCATION ""
//#define WU_LOCATION "90210"
// Country and city
#define WU_LOCATION "Belgium/Mechelen"
// 5 minutes between update checks. The free developer account has a limit
// on the number of calls so don't go wild.
#define DELAY_NORMAL (5*60*1000)
// 20 minute delay between updates after an error
#define DELAY_ERROR (20*60*1000)
#define WUNDERGROUND "api.wunderground.com"
// HTTP request
const char WUNDERGROUND_REQ[] =
"GET /api/" WU_API_KEY "/conditions/q/" WU_LOCATION ".json HTTP/1.1\r\n"
"User-Agent: ESP8266/0.1\r\n"
"Accept: */*\r\n"
"Host: " WUNDERGROUND "\r\n"
"Connection: close\r\n"
"\r\n";
// We start by connecting to a WiFi network
Serial.println();
Serial.println();
Serial.print(F("Connecting to "));
Serial.println(ssid);
WiFi.begin(ssid, pass);
delay(500);
Serial.print(F("."));
Serial.println();
Serial.println(F("WiFi connected"));
Serial.println(F("IP address: "));
static char respBuf[4096];
// TODO check for disconnect from AP
// Open socket to WU server port 80
Serial.println(WUNDERGROUND);
// Use WiFiClient class to create TCP connections
WiFiClient httpclient;
const int httpPort = 80;
if (!httpclient.connect(WUNDERGROUND, httpPort)) {
Serial.println(F("connection failed"));
delay(DELAY_ERROR);
return;
// This will send the http request to the server
Serial.print(WUNDERGROUND_REQ);
httpclient.print(WUNDERGROUND_REQ);
httpclient.flush();
// Collect http response headers and content from Weather Underground
// HTTP headers are discarded.
// The content is formatted in JSON and is left in respBuf.
int respLen = 0;
bool skip_headers = true;
while (httpclient.connected() || httpclient.available()) {
if (skip_headers) {
String aLine = httpclient.readStringUntil('\n');
//Serial.println(aLine);
// Blank line denotes end of headers
if (aLine.length() <= 1) {
skip_headers = false;
else {
int bytesIn;
bytesIn = httpclient.read((uint8_t *)&respBuf[respLen], sizeof(respBuf) - respLen);
Serial.print(F("bytesIn ")); Serial.println(bytesIn);
if (bytesIn > 0) {
respLen += bytesIn;
if (respLen > sizeof(respBuf)) respLen = sizeof(respBuf);
else if (bytesIn < 0) {
Serial.print(F("read error "));
delay(1);
httpclient.stop();
if (respLen >= sizeof(respBuf)) {
Serial.print(F("respBuf overflow "));
Serial.println(respLen);
delay(DELAY_ERROR);
return;
// Terminate the C string
respBuf[respLen++] = '\0';
Serial.print(F("respLen "));
//Serial.println(respBuf);
if (showWeather(respBuf)) {
delay(DELAY_NORMAL);
else {
delay(DELAY_ERROR);
bool showWeather(char *json)
StaticJsonBuffer<3*1024> jsonBuffer;
// Skip characters until first '{' found
// Ignore chunked length, if present
char *jsonstart = strchr(json, '{');
//Serial.print(F("jsonstart ")); Serial.println(jsonstart);
if (jsonstart == NULL) {
Serial.println(F("JSON data missing"));
return false;
json = jsonstart;
// Parse JSON
JsonObject& root = jsonBuffer.parseObject(json);
if (!root.success()) {
Serial.println(F("jsonBuffer.parseObject() failed"));
return false;
// Extract weather info from parsed JSON
JsonObject& current = root["current_observation"];
const float temp_f = current["temp_f"];
Serial.print(temp_f, 1); Serial.print(F(" F, "));
const float temp_c = current["temp_c"];
Serial.print(temp_c, 1); Serial.print(F(" C, "));
Blynk.virtualWrite(V1, temp_c); // virtual pin 1 = Temp in C
const char *humi = current[F("relative_humidity")];
Serial.print(humi); Serial.println(F(" RH"));
const char *weather = current["weather"];
Serial.println(weather);
const char *pressure_mb = current["pressure_mb"];
Serial.println(pressure_mb);
const char *observation_time = current["observation_time_rfc822"];
Serial.println(observation_time);
// Extract local timezone fields
const char *local_tz_short = current["local_tz_short"];
Serial.println(local_tz_short);
const char *local_tz_long = current["local_tz_long"];
Serial.println(local_tz_long);
const char *local_tz_offset = current["local_tz_offset"];
Serial.println(local_tz_offset);
return true;
