I have ported my Smart Home project from using old Blynk Legacy to Blynk IoT. This was really an easy and quick job to do. It took me a day. The time consumption was to make the new GUI and to set up more than 70 datastreams correctly. I have a Plus subscription, and using an Adafruit HUZZAH32 Feather card. I’m also using Visual Code, PlatformIO with platform = espressif32 and framework = arduino. Now I have a challenge with the Blynk IoT regarding virtualWrite and time consumption. It takes on average 68 milliseconds to complete just one call to virtualWrite, but the first write only takes approx 1 millisecond. I’m using micros() to measure time, see code below. The sample just uses four successive writes in a row. My aim is to be able to run on average 8 virtualWrites every 200 millisecond. Now it takes more than 540 milliseconds to complete. Is this how it should be? Am I doing something wrong here?
void TestBlynk_virtualWrite() ;
void MyTest();
static long my_ctr=0L;
void MyTest()
Serial.println("TestBlynk_virtualWrite()");
my_ctr=0L;
for (int i=0;i<10;i++)
TestBlynk_virtualWrite();
Serial.println("Test finished");
long long us1, us2, us3, us4,us5;
my_ctr++;
us1=micros();
Blynk.virtualWrite(V1, 11);
us2=micros();
Blynk.virtualWrite(V2, 22);
us3=micros();
Blynk.virtualWrite(V3, 33);
us4=micros();
Blynk.virtualWrite(V4, 44);
us5=micros();
Serial.printf("#%02ld: Delta usec V1: %lld, Delta usec V2: %lld, Delta usec V3: %lld, Delta usec V4: %lld\n",my_ctr,us2-us1, us3-us2, us4-us3, us5-us4);
OUTPUT using Blynk IoT, library blynkkk/Blynk@^1.1.0
#01: Delta usec V1: 1363, Delta usec V2: 67194, Delta usec V3: 67880, Delta usec V4: 66905
#02: Delta usec V1: 66495, Delta usec V2: 67222, Delta usec V3: 67535, Delta usec V4: 68241
#03: Delta usec V1: 67189, Delta usec V2: 66982, Delta usec V3: 66851, Delta usec V4: 67033
#04: Delta usec V1: 66828, Delta usec V2: 66793, Delta usec V3: 67387, Delta usec V4: 69201
#05: Delta usec V1: 67314, Delta usec V2: 67184, Delta usec V3: 68106, Delta usec V4: 67863
#06: Delta usec V1: 66759, Delta usec V2: 70468, Delta usec V3: 68816, Delta usec V4: 68910
#07: Delta usec V1: 69243, Delta usec V2: 68759, Delta usec V3: 69551, Delta usec V4: 67110
#08: Delta usec V1: 66424, Delta usec V2: 67458, Delta usec V3: 67834, Delta usec V4: 66990
#09: Delta usec V1: 66853, Delta usec V2: 67913, Delta usec V3: 69434, Delta usec V4: 69254
#10: Delta usec V1: 68779, Delta usec V2: 67383, Delta usec V3: 67137, Delta usec V4: 70250
Test finished
