Hello Blynk Community,
I’m working on a smart greenhouse project using Arduino UNO, DHT11 sensor, and several actuators (fan, heater, LED, pump, servo motor). I’m using Blynk with USB Serial (BlynkSimpleStream) to send data to the app.
I tested everything in Proteus simulation, and the logic works fine — sensors read correctly, and actuators react. However, Blynk.virtualWrite() doesn’t update the widgets on the mobile app.
My code calls
Blynk.virtualWrite(V2, t)
and Blynk.virtualWrite(V3, h)
every 3 seconds.
I can control actuators from the app to Proteus (like turning on the fan), so the write from Blynk app to Arduino works.
But the data from Arduino to Blynk app (e.g., temperature/humidity) doesn’t appear.
I use
Blynk.begin(Serial, auth)
and set the correct COM port in Arduino IDE.
I tried using Proteus + Virtual Serial Port Driver (COM3 ↔ COM1) and launched
blynk-ser.bat
with the correct parameters (-c COM3
Is it possible that Proteus is blocking outgoing virtual writes to Blynk Cloud? Or maybe the data is being written, but the app isn’t updating?
Here’s the simplified part of my code:
cpp
CopierModifier
float h = dht.readHumidity();
if (!isnan(h) && !isnan(t)) {
Blynk.virtualWrite(V2, t);
Blynk.virtualWrite(V3, h);
