Hello everyone, i need a help with my code. Im trying the use blynk.virtualWrite command on my function. But the simulation that i used a gave me an error. Can you guys see any mistake on my code thanks.
That is my main code
#define BLYNK_PRINT SwSerial
#include "kutuphane.h"
#include <LiquidCrystal.h>
LiquidCrystal lcd(13, 12, 11, 10, 9, 8);
#define ledPin1 4
#define ledPin2 5
#define ledPin3 6
#define ledPin4 7
#define vPin1 V12
#define vPin2 V13
#define vPin3 V14
#define vPin4 V15
#define sensor1 A0
#define sensor2 A1
#define sensor3 A2
#define sensor4 A3
#define sensor5 A4
#define sensor6 A5
float temp;
char auth[] = "Rn4MzFKwTAxOIljim9N_O6mGI3XUtgcQ";
int uyari = 0;
int uyari1 = 0;
int uyari2 = 0;
int uyari3 = 0;
int uyari4 = 0;
int i = 0;
int switch_1_ON = 0;
int ledPinState1 = LOW;
int ledPinState2 = LOW;
int ledPinState3 = LOW;
int ledPinState4 = LOW;
int SensorValue, SensorValue1, SensorValue2, SensorValue3, SensorValue4, SensorValue5;
BLYNK_CONNECTED() {
Blynk.syncVirtual(vPin1);
Blynk.syncVirtual(vPin2);
Blynk.syncVirtual(vPin3);
Blynk.syncVirtual(vPin4);
BLYNK_WRITE(vPin1) {
ledPinState1 = param.asInt();
digitalWrite(ledPin1, ledPinState1);
BLYNK_WRITE(vPin2) {
ledPinState2 = param.asInt();
digitalWrite(ledPin2, ledPinState2);
BLYNK_WRITE(vPin3) {
ledPinState3 = param.asInt();
digitalWrite(ledPin3, ledPinState3);
BLYNK_WRITE(vPin4) {
ledPinState4 = param.asInt();
digitalWrite(ledPin4, ledPinState4);
void vanaKapa() {
ledPinState1 = 0;
Blynk.virtualWrite(vPin1, 0);
digitalWrite(ledPin1, LOW);
void oku() {
//sensör 1 için
int SensorValue = analogRead(sensor1);
float SensorVolts = analogRead(sensor1) * 0.0048828125;
float SensorYuzde = analogRead(sensor1) / 10;
if (SensorYuzde >= 100) {
SensorYuzde = 100;
Blynk.virtualWrite(V5, SensorYuzde);
//sensor 2 için
int SensorValue2 = analogRead(sensor2);
float SensorVolts2 = analogRead(sensor2) * 0.0048828125;
float SensorYuzde2 = analogRead(sensor2) / 10;
if (SensorYuzde2 >= 100) {
SensorYuzde2 = 100;
Blynk.virtualWrite(V6, SensorYuzde2);
//sensor 3 için
int SensorValue3 = analogRead(sensor3);
float SensorVolts3 = analogRead(sensor3) * 0.0048828125;
float SensorYuzde3 = analogRead(sensor3) / 10;
if (SensorYuzde3 >= 100) {
SensorYuzde3 = 100;
Blynk.virtualWrite(V2, SensorYuzde3);
//sensor 4 için
int SensorValue4 = analogRead(sensor4);
float SensorVolts4 = analogRead(sensor4) * 0.0048828125;
float SensorYuzde4 = analogRead(sensor4) / 10;
if (SensorYuzde4 >= 100) {
SensorYuzde4 = 100;
Blynk.virtualWrite(V1, SensorYuzde4);
//sensor water için
int SensorValue5 = analogRead(sensor5);
float SensorVolts5 = analogRead(sensor5) * 0.0048828125;
float SensorYuzde5 = analogRead(sensor5) / 10;
if (SensorYuzde5 >= 100) {
SensorYuzde5 = 100;
Blynk.virtualWrite(V4, SensorYuzde5);
//sıcaklık için
temp = analogRead(A5);
int temperature = (temp * 500) / 1024;
Blynk.virtualWrite(V3, temperature);
lcd.setCursor(14, 2);
lcd.print(SensorValue);
lcd.setCursor(9, 3);
lcd.print(SensorVolts);
lcd.print(" V");
//Nem yüksek seviye kontrolü 1
if (SensorValue >= 800 && uyari == 0) {
Blynk.notify("1. SIRANIN NEM SEVİYESİ %80 OLDU. VANA KAPANIYOR.");
uyari = 1;
vanaKapa();
if (SensorValue < 800) {
uyari = 0;
// Nem yüksek seviye kontrolü 2
if (SensorValue2 >= 800 && uyari1 == 0) {
Blynk.notify("2. SIRANIN NEM SEVİYESİ %80 OLDU. VANA KAPANIYOR.");
uyari1 = 1;
uyari1 = 0;
//Nem yüksek seviye kontrolü 3
if (SensorValue3 >= 850 && uyari2 == 0) {
Blynk.notify("3. SIRANIN NEM SEVİYESİ %80 OLDU. VANA KAPANIYOR.");
uyari2 = 1;
uyari2 = 0;
//Nem yüksek seviye kontrolü 4
if (SensorValue4 >= 850 && uyari3 == 0) {
Blynk.notify("4. SIRANIN NEM SEVİYESİ %80 OLDU. VANA KAPANIYOR.");
uyari3 = 1;
uyari3 = 0;
//Su deposu Kontrolü
if (SensorValue5 <= 5 && uyari4 == 0) {
Blynk.notify("Su deposunda su kalmadı.");
uyari4 = 1;
uyari4 = 0;
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
pinMode(ledPin4, OUTPUT);
// set up the LCD's number of columns and rows:
lcd.begin(20, 4);
// Print a message to the LCD.
lcd.setCursor(0, 2);
lcd.print("Analog Value: ");
lcd.setCursor(0, 3);
lcd.print("Voltage: ");
SwSerial.begin(9600);
Blynk.begin(Serial, auth);
timer.setInterval(1000L, oku);
im just trying the call a vanaKapa(); in here .
uyari = 1;
vanaKapa();
uyari = 0;
and the vanaKapa() is
void vanaKapa() {
ledPinState1 = 0;
