Hey all,
Im having issues with Blynk Virtual Pins as an input from user. I wanted to make the virtual button to break the while loop but I cant seem to make the Blynk virtual pin inputting data reliably.
Board : Nano 33 IoT
IDE : Arduino IDE 2.0
Blynk Server
Here is my code (a simple replication code, cuz Im trying to integrate it into a bigger code):
#define BLYNK_TEMPLATE_ID "TMPLcs7W8DPD"
#define BLYNK_DEVICE_NAME "Virtual Pin"
#define BLYNK_AUTH_TOKEN "qjLKuRCsBbX105veJMmLc_b4Md5hnHOJ"
#include <WiFiNINA.h>
#include <WiFiUdp.h>
#include <RTCZero.h>
#include <BlynkSimpleWiFiNINA.h>
// WiFi Credentials (edit as required)
char ssid[] = ""; // Wifi SSID
char pass[] = ""; // Wifi password
// Object for Real Time Clock
RTCZero rtc;
int status = WL_IDLE_STATUS;
const int GMT = +8; // Time zone constant
int btnV5;
int btn;
// Print connection status
WiFiConnect();
printWiFiStatus();
// Start Real Time Clock
rtc.begin();
// Variable to represent epoch
unsigned long epoch;
// Variable for number of tries to NTP service
int numberOfTries = 0, maxTries = 6;
// Get epoch
do {
epoch = WiFi.getTime();
numberOfTries++;
while ((epoch == 0) && (numberOfTries < maxTries));
if (numberOfTries == maxTries) {
Serial.print("NTP unreachable!!");
while (1);
else {
Serial.print("Epoch received: ");
Serial.println(epoch);
rtc.setEpoch(epoch);
Serial.println();
btn = btnV5;
printTime();
//now = rtc.getHours() + GMT; //get hour now
int now = rtc.getSeconds();
while (now >= 30 && btnV5 != 1 && btn != 1) {
BLYNK_WRITE(V5);
Serial.println("while loop");
delay(2000);
Serial.println("btnV5 :" + String(btnV5));
Serial.println("btn :" + String(btn));
int btn = digitalRead(12);
if (btnV5 == 1) break;
else if (btn == 1) break;
void WiFiConnect() {
// Check if the WiFi module works
if (WiFi.status() == WL_NO_SHIELD) {
// Wait until WiFi ready
Serial.println("WiFi adapter not ready");
while (true);
// Establish a WiFi connection
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
// Wait 10 seconds for connection:
delay(10000);
void printWiFiStatus() {
// Print the network SSID
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// Print the IP address
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// Print the received signal strength
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
void print2digits(int number) {
if (number < 10) {
Serial.print("0");
Serial.print(number);
void printTime()
print2digits(rtc.getHours() + GMT);
Serial.print(":");
print2digits(rtc.getMinutes());
Serial.print(":");
print2digits(rtc.getSeconds());
Serial.println();
BLYNK_WRITE(V5)
int btnV5 = param.asInt();
Serial.println("blynk:" + String(btnV5));
I printed out the output, but when it was in the while loop, Blynk virtual button doesn’t relay into the loop. It only works outside of the loop.
Here is the output when it is not in the while loop. (Underlined)
& at the bottom (boxed) is when it is inside the loop. The virtual button can’t send the input data here.
My objective is to get the while loop to break when there is an input via the virtual button.
-Danial.
