details :
• Smartphone OS (Android) + version
• Blynk server
• Blynk Library version 0.6.1
i got problem with my virtual pin,
the data will display as [“1”,“2”,“3”,“4”] when send from arduino at pin V1.
but if i send to pin V2, the data will display as [“1”] after that [“2”] after that [“3”] and so on.
i use same coding to send data pin V1 and V2 in different arduino.
before that i had test V1 as terminal data function.
how can i change back V1 into data type as V2?
thank you.
#include <ESP8266_Lib.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
char auth[] = "xxxxxxxxxxx";
char ssid[] = "xxxxxx";
char pass[] = "xxxxxxx";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
// This function sends Arduino's up time every second to Virtual Pin (1).
void myTimerEvent()
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
String content= "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
Serial.println();
Blynk.virtualWrite(V2,content);
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate MFRC522
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
timer.setInterval(500L, myTimerEvent);
