I am currently trying to get Blynk working over a cellular connection. I am using a Arduino Mega 2560 with a Botletics SIM7000A shield. So far, my program is a spitting image of the TinyGSM BlynkClient example except for some changes made based on the Botletics LTE_Demo program. The Botletics example sets the baud rate of the SIM7000A to 9600, so I used the commands in the TinyGSM library to make the same changes. I am using the newest Blynk library version, v1.1.0. The program progresses through the startup commands at a painfully slow pace, and then appears to aquire connection. The program then passes off to Blynk, which starts up, but then crashes. My first hint that something was not right was that the getModemInfo() function returned nothing in the console print. Secondly, after the Blynk logo is printed to the console, I get a few lines of blank space, and then the program reattempts to connect to the GSM board, states that it cannot initialize the GSM board, and resets the board.
Console Output:
The program then repeats itself and retries to connect, over and over, repeating this same printout. Are the codes before and after the Blynk logo error codes? If so, is there a refrence someone can point me to for decoding?
The Botletics example program changes the baud rate to 9600 because of the limitations of software serial (per Botletics), so I continued that practice in my program. I see that the TinyGSM program does uses hardware serial for the Mega, which therefore can handle the 115200 baud rate, so my best guess is that something isn’t happy with the new 9600 baud rate in either the TinyGSM library, the actual SIM7000 chip, or the means of which attempt to change the baud rate. For reference, the default baud rate of the SIM7000A is 115200.
Here is my program:
#define TEST_LED 53 // pin for test LED
// Console Settings:
#define BAUD_RATE 9600 // baud rate for Botletics & statup info
#define SerialMon Serial
// Blynk Settings
#define BLYNK_TEMPLATE_ID "****************"
#define BLYNK_DEVICE_NAME "***************"
#define BLYNK_AUTH_TOKEN "***************"
#define BLYNK_FIRMWARE_VERSION "1.1.0"
#define BLYNK_DEBUG
#define SIMCOM_7000
#define TINY_GSM_MODEM_SIM7000
#define SerialAT Serial1
// For botletics SIM7000 shield
#define BOTLETICS_PWRKEY 6
#define RST 7
#define TX 10 // Microcontroller RX
#define RX 11 // Microcontroller TX
// Preprocessor Files:
#include <Adafruit_Sensor.h>
#include <TinyGsmClient.h>
// Global Vars
volatile bool ledCommand = false;
const char apn[] = "hologram";
const char user[] = "";
const char pass[] = "";
const char auth[] = BLYNK_AUTH_TOKEN;
// Instance Declarations
//BlynkTimer timer; // timer created for handing IoT data transfer freq
//SoftwareSerial SerialAT(TX, RX); // SW serial for modem comms
TinyGsm modem(SerialAT); // init modem
// Application Startup Tasks
SerialMon.begin(BAUD_RATE); // set baud rate for Console
// turn on GSM modem
SerialMon.println("Turn on modem...");
pinMode(RST, OUTPUT);
digitalWrite(RST, HIGH); // Default state
pinMode(BOTLETICS_PWRKEY, OUTPUT);
digitalWrite(BOTLETICS_PWRKEY, LOW);
delay(1100); // At least 1s, per botleticsSIM7000.h
digitalWrite(BOTLETICS_PWRKEY, HIGH);
delay(4000);
SerialMon.println("Modem On");
SerialAT.begin(115200); // Default SIM7000 shield baud rate
modem.restart();
SerialMon.println("Modem Restart");
modem.factoryDefault();
SerialMon.println("Factory Default");
// set GSM baud rate
SerialMon.println("Configuring to 9600 baud");
modem.setBaud(9600);
delay(100); // Short pause to let the command run
SerialAT.begin(BAUD_RATE);
delay(6000);
// init modem
SerialMon.println("Initializing modem...");
modem.restart();
SerialMon.println("Wait for Net...");
modem.waitForNetwork(300000L); // 30s timeout
//get modem info
String modemInfo = modem.getModemInfo();
Serial.print("Modem Info: ");
Serial.println(modemInfo);
delay(2000);
// connect to Blynk
Serial.println("Connecting to Blynk...");
// Setup Test LED
pinMode(TEST_LED, OUTPUT); // enable as output
digitalWrite(TEST_LED, LOW); // turn off
}// End Application Startup Tasks
// Application Run Tasks
// ACTIONS THAT ARE CONTINUOUS
}// End Application Run Tasks
// Function Declarations
// Function called every time the light button changes virtual pin V0 (LightVirtual)
BLYNK_WRITE(V0)
ledCommand = param.asInt(); // assigns value to ledCommand
digitalWrite(TEST_LED, ledCommand);
I can connect to the internet using the Botletics demo program without issue, and in roughly 1/10th the time the TinyGSM program takes to connect to Blynk. Anything I am missing that could be causing this?
Here is the SIM7000A board I am using, and the example program that is working correctly:
Botletics Example
Botletics Home
And the TinyGSM example:
TinyGSM Blynk
Just a note; the TinyGSM example also crashes the same way, which I originally thought was an issue with not sending a on/off/reset command to the SIM7000A and also using the 115200 baud rate. The only difference is the codes around the Blynk logo. See the picture below for reference.
Any help is greatly appreciated, thanks in advance
