@s.d.engineering @sh.abar.mard issue confirmed. Working on fix.
Good luck.
Regards.
what about this issues for new released server ? or we should to wait for new android app release?
It Seems that the issue is in the app, and a fix will be released during next two or three days.
Sure you know better.
but i have problem with both of os(Android and ios) so it seems maby it is in server side or both(mobile os and server)
I sent my log. That said mismatch sender id and error fcm.google.com
@s.d.engineering what server version do you have and app versions? iOS works, we tested it recently.
You could try our new log build, in which this issue should be fixed: https://www.dropbox.com/s/xk8pfobfb5x7pwc/blynk_app-log.apk?dl=0
I’m on latest version of android 2.17.0 app and ios 2.13 and server 28.10
So what about ios version?
@Dmitriy
@BlynkAndroidDev
Now i receive push on IOS but Android anything look at my log:
18:52:37.320 ERROR- Error sending push. Reason MismatchSenderId
18:53:08.220 ERROR- Error sending push. Reason MismatchSenderId
Android 2.17.0
ios 2.13.0 Received Notification
Server .28.10
That’s correct now . We have the issue with pushes on the Local server with the latest Android app. Working on fix.
Ok, Good luck Man.
Best Regards
@Dmitriy what about pushes notification on every project separately ? because i use a shared project doesn’t use notification but notification pushed on that and the pushed notification is for other project .
Checking.
You know that The notifications are very important because we use it for trigger TASKER APP and when it is work with issues Scenarios work with very issues
Please Write the result after your test. Thank you.
@Dmitriy sorry for this question but this is very important for me:
why the new method of notification work with internet and when i have no access to the internet server log this and notification doesn’t work
22:05:15.554 ERROR- Error sending push. Reason connection timed out: fcm.googleapis.com/172.217.17.202:443
22:05:26.704 ERROR- Error sending push. Reason Request timeout to fcm.googleapis.com/216.58.206.202:443 after 60000 ms
22:06:02.022 ERROR- Error sending push. Reason connection timed out: fcm.googleapis.com/172.217.17.202:443
what about future it is required to internet forever or maybe just now and some improvement needed to use notification without internet?
@Dmitriy
what about before than notification goes to firebase?
I think in past notification work without internet.
Nope. This is not possible.
