@s.d.engineering @sh.abar.mard notifications were fixed for local server.
Confirmed as working for me with Android App 2.17.1
and server-0.29.0-java8.jar
0.29.10
Great.
Nope
you right.
Do not send commands to shared project from non-shared project;
is it mean notification wonât be push to other shared project?
i mean each project just push that project notifications.
Remove old GET_SHARED_PROJECT command;
so we have to share the project again(reshare)?
Correct. However, this is also requires fix on iOS. It is not published yet. However, Android should work fine.
No. This is internal code thing.
I have a problem with notification on android:
Sometimes(most when app is closed) notification doesnât push at time and it push when i open app(i.e. Several hours after action) this is a old message but push on screen. So i setup a trigger action on tasker so it is too late to run that action. This is bad.
me too, observed something similar in the last days. only sometimes happens; mostly it works correctly. very strange.
@Dmitriy
Yes it is on âHIGHâ always.
i have many problem with push on android. in android when app is closed it doesnât push any notification.(sometimes)
exactly.
@Dmitriy
ok Thatâs not important when we donât use Tasker App But when tou trigger a action on Tasker app so you miss the action or you have many delay to trigger that acion.this is so bad (as @pavel said best trigger method for Tasker is notification until now. forthere we mis that option sometimes.
May I kindly ask you to stop tagging me when my reply is not needed. Also, I donât know what tasker is, and i most likely didnât give any advices on it
sorry
Iâm an iOS user, so Iâm not sure I can give any comments on how to use this tasker stuff.
No, thatâs not an expected behavior, the meaning of the push notifications is to work when the app is closed.
@s.d.engineering @wanek Blynk Cloud or local servers, any ideas on the ways to reproduce this behaviour?
