Hi, Pavel, here’s my sketch and the Blynk Yun exemple do works for me.
I am wondering if there is any conflict between the Blynk sketch and the Temboo ones.
Thanks for replying. I will post it to the Temboo forum too.
#include < Ultrasonic.h >
#include < OneWire.h >
#include < DallasTemperature.h >
#include < Bridge.h >
#include < Temboo.h >
#include “TembooAccount.h”
#include < Servo.h >
#include < Process.h >
#include < BlynkSimpleYun.h >
Process date;
#define ONE_WIRE_BUS 7
const int PinIN1 = 8;
const int PinIN2 = 9;
const int PinIN3 = 10;
const int PinIN4 = 11;
#define TRIGPIN 12
#define ECHOPIN 13
Ultrasonic ultrasonic(TRIGPIN, ECHOPIN);
Servo myservo;
const unsigned long RUN_INTERVAL_MILLIS = 60000;
unsigned long lastRun = (unsigned long) - RUN_INTERVAL_MILLIS;
sensors.begin();
pinMode(PinIN1, OUTPUT);
pinMode(PinIN2, OUTPUT);
pinMode(PinIN3, OUTPUT);
pinMode(PinIN4, OUTPUT);
pinMode(5, OUTPUT);
myservo.attach(6, 800, 2400);
char auth[] = “”;
Blynk.begin(auth);
while (Blynk.connect() == false) {} //wait until connected
delay(4000);
while (!Serial);
Bridge.begin();
float temperature = sensors.getTempCByIndex(0);
if (temperature > 29) //如果溫度大於 29 度,啟動風扇
digitalWrite(8, LOW);
digitalWrite(11, HIGH);
digitalWrite(8, HIGH);
digitalWrite(11, LOW);
float height = 15.75; // 水族箱高度
long microsec = ultrasonic.timing();
float cm = ultrasonic.convert(microsec, Ultrasonic::CM); // 感測到的距離,單位: 公分
float waterlevel = height - cm; // 計算水位高度
float brightness = analogRead(A0);
while (brightness <= 20) {
digitalWrite(9, HIGH);
delay(3000);
digitalWrite(9, LOW);
digitalWrite(10, HIGH);
delay(3000);
blynk (temperature, waterlevel);
unsigned long now = millis();
if (now - lastRun >= RUN_INTERVAL_MILLIS) {
lastRun = now;
Feed();
saveData( temperature, waterlevel, brightness );
void Feed() {
for (int i = 2400; i >= 800; i -= 300) {
myservo.writeMicroseconds(i);
delay(300);
for (int i = 800; i <= 2400; i += 300) {
delay(300);
Serial.println(“Running SendAnEmail…”);
TembooChoreo SendEmailChoreo;
SendEmailChoreo.begin();
const String GMAIL_USER_NAME = "k55466909@gmail.com";
const String GMAIL_PASSWORD = “”;
const String TO_EMAIL_ADDRESS = "k55466909@gmail.com";
SendEmailChoreo.setAccountName(TEMBOO_ACCOUNT);
SendEmailChoreo.setAppKeyName(TEMBOO_APP_KEY_NAME);
SendEmailChoreo.setAppKey(TEMBOO_APP_KEY);
SendEmailChoreo.setChoreo("/Library/Google/Gmail/SendEmail");
SendEmailChoreo.addInput(“Username”, GMAIL_USER_NAME);
SendEmailChoreo.addInput(“Password”, GMAIL_PASSWORD);
SendEmailChoreo.addInput(“ToAddress”, TO_EMAIL_ADDRESS);
SendEmailChoreo.addInput(“Subject”, “自動化養殖”);
SendEmailChoreo.addInput(“MessageBody”, “自動餵食機剛剛餵食了一次”);
if (SendEmailChoreo.run() == 0) {
Serial.println(“Success! Email sent!”);
while (SendEmailChoreo.available()) {
char c = SendEmailChoreo.read();
Serial.print©;
SendEmailChoreo.close();
void saveData(float temperature, float waterlevel, float brightness) {
//Get date-------------------------------------------------------------------------
date.begin("/bin/date");
date.addParameter("+%d/%m/%Y %T");
date.run();
//String------------------------------------------------------------------------------
String rowData;
rowData += String(date.readString()) + “,” + String(temperature) + “,” + String(brightness) + “,” + String(waterlevel);
Serial.println(“Appending value to spreadsheet…”);
TembooChoreo AppendRowChoreo;
AppendRowChoreo.begin();
const String CLIENT_ID = “430501448281-jama7h23kbj3dba2hvtlkehhf1oo2nc1.apps.googleusercontent.com”;
const String CLIENT_SECRET = “”;
const String REFRESH_TOKEN = “”;
const String SPREADSHEET_TITLE = “chloe”;
AppendRowChoreo.setAccountName(TEMBOO_ACCOUNT);
AppendRowChoreo.setAppKeyName(TEMBOO_APP_KEY_NAME);
AppendRowChoreo.setAppKey(TEMBOO_APP_KEY);
AppendRowChoreo.setChoreo("/Library/Google/Spreadsheets/AppendRow");
AppendRowChoreo.addInput(“ClientID”, CLIENT_ID);
AppendRowChoreo.addInput(“ClientSecret”, CLIENT_SECRET);
AppendRowChoreo.addInput(“RefreshToken”, REFRESH_TOKEN);
AppendRowChoreo.addInput(“SpreadsheetTitle”, SPREADSHEET_TITLE);
AppendRowChoreo.addInput(“RowData”, rowData );
if (AppendRowChoreo.run() == 0) {
Serial.println(“Success! Appended " + rowData);
Serial.println(”");
while (AppendRowChoreo.available()) {
char c = AppendRowChoreo.read();
Serial.print©;
AppendRowChoreo.close();
void blynk (float temperature, float waterlevel) {
Blynk.virtualWrite(V0, temperature);
Blynk.virtualWrite(V1, waterlevel);
