Blynk.syncVirtual not working on esp32 BLE
I am using a esp32 in BLE mode and making a outboard fuel -meter. On start up I call Blynk.syncVirtual(V3) to get the total fuel consumption followed by a corresponding BLYNK_WRITE(V3) but this function never gets called!? I have tried syncAll() as well but none of my BLYNK_WRITE gets called.
It works with my esp8266 but not esp32 in BLE mode!?
#include <BlynkSimpleEsp32_BLE.h>
#include <BLEDevice.h>
#include <BLEServer.h>
BlynkTimer timer1;
volatile double trip_volume = 0.0;
volatile double n_pulse = 0.0;
volatile double total_consumption = 1.0;   %%UPDATE THIS AT BOOT
int Signal_Pin = 13;
volatile double Flow = 0.0;
float dt = 1.0;
float v_disp = 0.17; // mL per pulse
float F_pulse = 98.0;  //98pulse per sek = 1L/min
float speed_kmt;
float speed_knots;
float speed_mps;
float Flow_lpkm;
bool going_to_sleep = false;
bool syncedonboot = false;
int noConnect = 0;
int update_timer;
int boot_timer;
int units;
float speed_units;
float conv = 1.944;
char auth[] = "xxx";
  attachInterrupt(digitalPinToInterrupt(Signal_Pin),pulse, RISING);
  Blynk.setDeviceName("Blynk");
  Blynk.begin(auth);
  delay(200);
BLYNK_CONNECTED()
Serial.println("connected and syncing");
Blynk.syncVirtual(V3);  %% <----------- HERE I TRY TO GET THE LATEST CLOUD DATA
delay(500);
BLYNK_APP_DISCONNECTED() {
timer1.disable(update_timer);
Serial.println("app diconnected");
BLYNK_WRITE(V3)  <----------------- THIS NEVER GETS CALLED
  Serial.println("synced at boot");
  delay(50);
  total_consumption = param.asFloat(); // get the latest fuel consuption from server
  syncedonboot = true;
  update_timer = timer1.setInterval(1000L*dt, update_values);
BLYNK_WRITE(V5)
  units = param.asInt(); // Swith between units
  delay(20);
BLYNK_WRITE(V8)
  dt = param.asInt(); // Swith between units
  delay(20);
  Serial.print("dt is now");
  Serial.println(dt);
void update_values()
  Flow = n_pulse / F_pulse * 1 / dt; // in [L/min]
  speed_kmt = speed_knots/0.54; //mps to kmt
  Flow_lpkm = Flow * 60.0 / (speed_kmt); // in ???
  if (units == 0){
  speed_units = speed_knots;
  else{
  speed_units = speed_kmt;
  Blynk.virtualWrite(V0, Flow);
  delay(20);
  Blynk.virtualWrite(V1, trip_volume);
  delay(20);
  Blynk.virtualWrite(V3, total_consumption);
  delay(20);
  Blynk.virtualWrite(V2, Flow_lpkm);
  delay(20);
  Blynk.virtualWrite(V6, speed_units);
  Serial.println("updating values");
  Serial.println(Flow);
  Serial.println(trip_volume);
  n_pulse = 0;
BLYNK_WRITE(V7)
   Serial.println("speed is synced");
   speed_knots = param[3].asFloat()*conv;
BLYNK_WRITE(V4)
  trip_volume = 0.0;
  Blynk.virtualWrite(V1, 0.0);
void pulse()   //measure the quantity of square wave
  trip_volume += 1.0 / 5880.0;  // in Liters
  total_consumption += 1.0 / 5880.0;  // in Liters
  n_pulse += 1.0;
  timer1.run();
I think it’s one of those commands that does t work with Bluetooth…
