This is my first time using blynk and all I want todo is use a virtual button to control a physical led however blynk works fine with the button and in the serial monitor the button displays either 1 or 0 however when I add the led and put the line “pinMode(ledPin, OUTPUT);” it stops connecting to the app. I know its this as when I take out that line of code it works perfectly.
Hardware and software
• Arduino UNO with ESP8266
• IOS
http://twitter.com/blynk_app
You’ll need:
- Blynk App (download from AppStore or Google Play)
- ESP8266 board
example.
char auth[] = "****";
#define ledPin 6
char ssid[] = "****";
char pass[] = "****";
BLYNK_WRITE(V5)
Serial.println(param.asInt());
if (param.asInt() == 1) {
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
// to avoid delay() function!
