I don’t really understand any of your responses to the issues I pointed out earlier. If you want assistance then you need to verbalise your questions better.
This makes no sense at all.
Pins 1 and 3 are the UART0 pins that are also connected to to the USB port (via a TTL to USB chip). You’re attempting to use them to also communicate with your SIM800.
The ESP32 also has two other hardware UARTs, so there is no need to use software serial to create a software UART.
You’ve already read this article, because you liked it yesterday, but you clearly haven’t understood it…
