nodemcu wifi
os: iOs 14
type of server: Blynk server
Library version: 0.6.1
Hello, I’m using Blynk for open my slide gates. Gates controlled by FAAC engine and have FAAC automatic board.
This board has 2 physical ports for short opens and fully opened gates.
To this ports I plug 2x relay module, which controlled by modemcu with Blynk.
It’s works, but I have some trouble with stability.
1.sometimes gates opened itself, and I don’t know why. (Rise of the machines?)
2. Sometimes nodemcu goes down and I also don’t know the reason.
To resolved this problems think i need something like log in blynk. I tried to realise it through the terminal widget in blynk, but in this case i have problem with very often sends to blynk server. Algorithm is:
1.blynk check the state of button in app
2.if state of button == 1, send HIGH to relay pin
3. Switch off button in the app
4.send to terminal message with date, time and action (button was pushed).
Even if i use blynk.timer, all of those steps of algorithm have to done in one cycle. It’s too faster to blynk i think. Also log is useless without ip address from which recieved GET request ( i use Siri with GET request to blynk open gates) is it possible to know ip address and print it to terminal ?
//#define BLYNK_PRINT Serial
#include <ArduinoOTA.h>
#include "uptime.h"
#include "string.h"
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
#define DEBUG 1 // Set up debug mode
// AUTH
#if (DEBUG == 1)
char auth[] = "Token_debug"; // Токен для отладки
char esp_hostname[] = "esp_gate_debug";
#else
char auth[] = "Token"; // Боевой токен
char esp_hostname[] = "esp_gate";
#endif
char ssid[] = "Ssid"; //Название WiFi-сети
char pass[] = "pass"; //Пароль
//Widgets
BlynkTimer timer; // timer for sending data to blynk
WidgetRTC rtc; // Start rtc widget
WidgetTerminal terminal(V21);
WidgetLCD lcd(V3);
char currentTime[9];
char currentDate[11];
BLYNK_CONNECTED() {
// Synchronize time on connection
rtc.begin();
// timer for opened gate //
#define PERIOD 5000
unsigned long openTimer = 0;
// ESP pins
#define PIN_MAGNET D7 // Physical pin to a3144 sensor
#define PIN_RELAY1 D6 // Physical pin to Relay for full open
#define PIN_RELAY2 D5 // Physical pin to Relay short open
#define garageSensorSW digitalRead(PIN_MAGNET) // read hall sensor
// virtual pins for BLYNK
#define BL_UPTIME V5 // uptime pin
#define BL_RSSI V6 // signal strength pin
#define BL_RELAY1 V1 // full open gate
#define BL_RELAY2 V2 // short open gate
// relay
BLYNK_WRITE(BL_RELAY1) //функция, отслеживающая изменение виртуального пина
int pinValue1 = param.asInt(); //переменная текущего состояния виртуального пина
if (pinValue1 == 1) {
digitalWrite(PIN_RELAY1, LOW);
delay (500);
digitalWrite(PIN_RELAY1, HIGH);
Blynk.virtualWrite(BL_RELAY1, 0);
// Terminal logging
sprintf(currentDate, "%02d/%02d/%04d", day(), month(), year());
sprintf(currentTime, "%02d:%02d:%02d", hour(), minute(), second());
terminal.print("[" + String(currentDate) + " | ");
terminal.print(String(currentTime) + "]");
terminal.println("Button " + String(BL_RELAY1) + " was pushed");
terminal.println();
terminal.println();
terminal.flush();
BLYNK_WRITE(BL_RELAY2) //функция, отслеживающая изменение виртуального пина
int pinValue2 = param.asInt(); //переменная текущего состояния виртуального пина
if (pinValue2 == 1) {
digitalWrite(PIN_RELAY2, LOW);
delay (500);
digitalWrite(PIN_RELAY2, HIGH);
Blynk.virtualWrite(BL_RELAY2, 0);
void garageMagSensor ()
lcd.clear();
//Serial.print("Hall sensor state: ");Serial.println(garageSensorSW); // отображение статуса датчика хола в serial порт, для отладки.
if (garageSensorSW == !LOW)
lcd.print(2, 0, "Ворота открыты"); // LCD print, column 2, row 0.
if (millis() - openTimer >= PERIOD)
unsigned long sec = openTimer / 1000 ;
//unsigned long minutes = openTimer / 1000 / 60;
String notifyMessage=String("Ворота открыты ")+sec+String(" секунд") ;
lcd.print(4, 1, sec);
lcd.print(8,1, "сек");
openTimer += PERIOD;
switch(sec)
case 180:
case 600:
Blynk.notify(notifyMessage);
break;
lcd.print(2, 0, "Ворота закрыты"); // LCD print, column 2, row 0
openTimer = 0;
void sendUptime ()
uptime::calculateUptime();
String uptime_format = (String)(uptime::getDays()) + "d:" + (String)(uptime::getHours() ) + "h:" + (String)(uptime::getMinutes()) + "m" ;
Blynk.virtualWrite(BL_UPTIME, uptime_format);
//String currentTime = String(hour()) + ":" + minute() + ":" + second();
void clockDisplay()
// You can call hour(), minute(), ... at any time
// Please see Time library examples for details
//String currentDate = String(day()) + " " + month() + " " + year();
// Send time to the App
Blynk.virtualWrite(V0, currentTime);
// test terminal button state
BLYNK_WRITE(V20)
int pinValue20 = param.asInt();
if(pinValue20 == 1) {
terminal.print(myTime + "]");
terminal.println("Test Button was pushed");
terminal.println();
terminal.println();
terminal.flush();
void setup() //основная функция, выполняется один раз при подаче питания на микроконтроллер
Serial.begin(115200); //открываем серийный порт
WiFi.mode(WIFI_STA); // режим клиента
WiFi.hostname(esp_hostname); //
WiFi.begin(ssid, pass);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("Connection Failed! Rebooting...");
delay(5000);
ESP.restart();
setSyncInterval(10 * 60); // Sync interval in seconds (10 minutes)
// Display digital clock every 10 seconds
timer.setInterval(10000L, clockDisplay);
ArduinoOTA.onError([](ota_error_t error) {
ESP.restart();
ArduinoOTA.setHostname(esp_hostname); // !!!!
ArduinoOTA.begin();
//Terminal
terminal.clear();
// This will print Blynk Software version to the Terminal Widget when
// your hardware gets connected to Blynk Server
terminal.println(F("Blynk v" BLYNK_VERSION ": Device started"));
terminal.println(F("-------------"));
terminal.flush();
// Pin mode, bootstate
pinMode(PIN_RELAY1, OUTPUT); //объявляем D4 "выходным" пином
pinMode(PIN_RELAY2, OUTPUT);
pinMode(PIN_MAGNET, INPUT_PULLUP);
digitalWrite(PIN_MAGNET, LOW);
// Setup a function with timer
timer.setInterval(10000L, garageMagSensor);
timer.setInterval(30000L, sendUptime);
timer.setInterval(30000L, clockDisplay);
Blynk.virtualWrite(BL_RSSI, WiFi.RSSI());
void loop() //основная функция, которая выполняется постоянно по кругу
Blynk.run(); // lets start magic
ArduinoOTA.handle();
