This sketch for Arduino nano:
renders the following error:
Arduino: 1.8.5 (Windows 7), Board: “Arduino Nano, ATmega168”
Sketch uses 26490 bytes (184%) of program storage space. Maximum is 14336 bytes.
Global variables use 1343 bytes (131%) of dynamic memory, leaving -319 bytes for local variables. Maximum is 1024 bytes.
Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
Error compiling for board Arduino Nano.
so the question is: is there a way to get blynk running on an Atmega168? are there certain settings that I need to change?
I’m not really interested in the above sketch, but as I get mem issues in my own sketch I thought I try out a ‘default’ sketch first…no luch there either.
edit: note that I tried using:
#define BLYNK_NO_BUILTIN
#define BLYNK_NO_INFO
#define BLYNK_NO_FANCY_LOGO
#define BLYNK_NO_FLOAT
still not working
Hi wolph42,
have you tried to comment on the line #define BLYNK_PRINT Serial ?
in this way: //#define BLYNK_PRINT Serial
regards
I’m not aware of any
The smallest I managed to fit the working code in (some sensor, Blynk, LED display…) is about 25k on ATMEGA32… (the same amount as casual UNO)
Hey! I managed to fit Blynk into 16kB of ATMEGA16 flash with ESP WiFi connectivity!
Using library Blynk at version 0.5.3 in folder: D:\Arduino\Szkice\libraries\Blynk
Sketch uses 14698 bytes (92%) of program storage space. Maximum is 15872 bytes.
Global variables use 680 bytes (66%) of dynamic memory, leaving 344 bytes for local variables. Maximum is 1024 bytes.
I know it wasn’t the question, but I couldn’t resist and had to find the setup that fits into 16kB flash
can you share that sketch/setup?
Tomorrow… I’m just finishing this day …
Here you have: But hardly usable, because what is left after disabling built-in functionality?? I have NO_BUILTIN declared in library config, so here it is omitted
#include <ESP8266_Lib.h>
char pass[] = "YourPassword";
#define EspSerial Serial
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
//Serial.begin(9600);
// Set ESP8266 baud rate
Using library BlynkESP8266_Lib in folder: D:\Arduino\Szkice\libraries\BlynkESP8266_Lib (legacy)
thnx ill check this out…probly in a couple of weeks (holiday)
