Hello
i have blynk server 0.41.14 on Synology ARM6/7 with Java 8.
java -version
openjdk version “1.8.0_212” OpenJDK Runtime Environment (IcedTea 3.12.0) (linux-gnu build 1.8.0_212-b04) OpenJDK Client VM (build 25.212-b04, mixed mode)
the problem is thet it need JAVA 11 but this synology not load JAVA 11
i understand thet some problem on Blynk server was for a incompatible version from JAVA and BlynkServer
After thoused test i can fix the Blink Server ?
1 - oldest blynk version (where is it?)
2 - new HW Raspberry?
3 - Can i found the 11 version of JAVA for Synology arm 6/7 ?
