i have my own blynk server running in docker using the compilation of maxbanton / blynk-server: latest.
I need to log in via nginx reverse proxy to my server.
My ngnix configuration:
server {
listen 443;
listen [::]: 442;
server_name blynk.nahorniak.cz;
location / {
proxy_pass https://192.168.1.10:9443/;
Setting up blynk server:
initial.energy = 0
allow.reading.widget.without.active.app = true
user.message.quota.limit = 100
logs.folder = / data / logs
user.dashboard.max.limit = 3
lcd.strings.pool.size = 6
server.ssl.key =
webhooks.response.size.limit = 96
hardware.mqtt.port = 8441
table.rows.pool.size = 100
terminal.strings.pool.size = 25
admin.email=admin@nahorniak.cz
admin.rootPath = / index.html
user.widget.max.size.limit = 20
listen.address =
mail.properties = / config / mail.properties
blocking.processor.thread.pool.limit = 6
stats.print.worker.period = 60000
enable.db = false
force.port.80.for.csv = false
enable.raw.db.data.store = false
restore.host = blynk.nahorniak.cz
contact.email=admin@nahorniak.cz
server.host = blynk.nahorniak.cz
csv.export.data.points.max = 43200
restore = false
user.profile.max.size = 256
allow.store.ip = true
allowed.administrator.ips = 0.0.0.0 / 0, :: / 0
net.interface = eth
webhooks.frequency.user.quota.limit = 1000
http.port = 8080
web.request.max.size = 524288
user.devices.limit = 50
async.logger.ring.buffer.size = 2048
user.tags.limit = 100
server.ssl.key.pass =
admin.pass = admin
hard.socket.idle.timeout = 10
product.name = Gas | nahorniak
data.folder = / data
map.strings.pool.size = 25
profile.save.worker.period = 60000
https.port = 9442
log.level = info
server.ssl.cert =
force.port.80.for.redirect = false
notifications.queue.limit = 2000
notifications.frequency.user.quota.limit = 10
Currently, web administration works, but login through the application does not.
Unfortunately, I did not find any solution here in the forum.
I’m really a beginner, please use the basic instructions / advice.
Thanks…
