Hello -
I am new to Blynk and trying to run a Blynk Server on a Raspberry Pi 3. I am following the instructions here: https://github.com/blynkkk/blynk-server#advanced-local-server-setup. After I enter the following in the terminal,
java -jar server-0.39.4-java8.jar -dataFolder /home/pi/Blynk
I get this output:
Blynk Server 0.39.5-SNAPSHOT successfully started.
All server output is stored in folder '/home/pi/logs' file.
When I try to log in to the app though I get an error,
“Something went wrong when connecting to the server. Please check to see if port 9443 is open in your network.”
I have tried to both log in and create a new account and I receive the same error.
I checked the ports using sudo netstat -lptn
Output is here:
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 435/sshd
tcp6 0 0 :::9443 :::* LISTEN 1888/java
tcp6 0 0 :::8080 :::* LISTEN 1888/java
tcp6 0 0 :::22 :::* LISTEN 435/sshd
tcp6 0 0 :::8440 :::* LISTEN 1888/java
tcp6 0 0 :::8441 :::* LISTEN 1888/java
Any suggestions are appreciated.
