Have you tried running the TinyGsm factory reset tool from the Github page?
What happens if you then run the Blynk example from the Github page, without any modifications (other than putting 8n your Blynk and APN credentials)?
Thanks a lot everyone for the support. Just got a SIM800 module. Its working fine as before.
TinyGSM v0.3.3 is out and should work with SIM900 again (should be also available soon in the Library Manager)
