Hi friends. is it possible to using blynk server and EthernetServer server; in sketch ?
I write a sketch but compiling error. the error is: conflicting declaration ‘EthernetServer server’
any idea to fix ?
#include <Ethernet.h>
#include <Wire.h>
#include <DFRobot_SHT20.h>
#include <NewEEPROM.h>
#include <NetEEPROM.h>
#include <EthernetReset.h>
char auth[] = "5K4ffJVQB2DkhL8VWp3eawe4bRScy8Vr";
char server[] = "172.16.20.254";
#define W5100_CS 10
#define pirPin 2
EthernetReset reset(8080);
EthernetServer server(80);
DFRobot_SHT20 sht20;
int x;
int alarm;
int slider;
BLYNK_WRITE(V7)
alarm = param.asInt();
BLYNK_WRITE(V8)
slider = param.asInt();
reset.begin();
Blynk.begin(auth, server, 8080);
sht20.initSHT20();
pinMode(pirPin, INPUT);
delay(100);
sht20.checkSHT20();
timer.setInterval(2000L, TH);
timer.setInterval(2000L, te);
timer.setInterval(30 * 1000, reconnectBlynk);
void TH()
float humd = sht20.readHumidity();
Blynk.virtualWrite(V1, humd);
float temp = sht20.readTemperature();
Blynk.virtualWrite(V2, temp);
void te()
if (alarm == 1 && sht20.readTemperature() >= slider ) {
Blynk.notify("room high temp");
void reconnectBlynk() {
if (!Blynk.connected()) {
Serial.println("Lost connection");
if (Blynk.connect()) {
Serial.println("Reconnected");
else {
Serial.println("Not reconnected");
reset.check();
if (Blynk.connected()) {
thanks
