Hi friends. after upgrade to 0.38.3 cannot be register user and login and the blynk admin page not available
Are you sure you updated everything, including your startup file, you have the .jar file in the correct location, etc?
I just downloaded and updated to server-0.38.3-java8.jar
and everything is working as normal, including my Admin page.
yeah. after running server it make recommended folders in blynk directory. the server is latest raspbian lite on raspberrypi 2 and java is installed.
@Dmitriy blynk server error when running. Does blynk server need openjdk ?
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x76892a18, pid=1133, tid=1983362160
# JRE version: Java(TM) SE Runtime Environment (8.0_65-b17) (build 1.8.0_65-b17)
# Java VM: Java HotSpot(TM) Client VM (25.65-b01 mixed mode linux-arm )
# Problematic frame:
# V [libjvm.so+0x497a18]
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/pi/Blynk/hs_err_pid1133.log
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
Aborted
problem solved by reinstalling raspbian !
