Blynk Reconnect when wifi connection is lost
I made a simple Blynk program, but the connection to my internet is not great. sometimes he is losing connection, but it doesn’t reconnect to my wifi.
how do I intergrade a reconnect function to the wifi?
I hope you can help me with this.
Thank you for your help!
(im using a Wemos d1 mini)
#define BLYNK_TEMPLATE_ID "XXXX"
#define BLYNK_DEVICE_NAME "XXXXX"
#define BLYNK_AUTH_TOKEN "XXXXXXXXX"
char ssid[] = "XXXXXXX";
char pass[] = "XXXXXXX";
int Open  = 13;
int Dicht = 12;
BLYNK_WRITE(V0) {
  int pinvalue = param.asInt ();
  digitalWrite(Open,pinvalue);
BLYNK_WRITE(V1) {
  digitalWrite(Dicht,pinvalue);
  delay(100);
pinMode(Open,OUTPUT);
pinMode(Dicht,OUTPUT);
void connectionstatus() {
  if ((WiFi.status() != WL_CONNECTED) ) {
    Serial.println("Reconnecting to WiFi...");
    WiFi.disconnect();
    WiFi.begin(ssid, pass);
      delay(100);
      Serial.print(".");
    Serial.println();
    //Alternatively, you can restart your board
    //ESP.restart();
    Serial.println("wifi OK");
  if (!Blynk.connected() ) {
    Serial.println("Lost Blynk server connection");
    Blynk.connect();
    Serial.println("Blynk OK");
If the controller controls something (a relay), then the use of “while” is highly undesirable.
You can add a count flag and exit the while loop at the desired time (more than 10 seconds) else there’s no way to check and reconnect to wifi.
Im sorry, I Should mensioned that. There are 2 relays on it. It is for opening and closing a gate 2 times a day. Hé only has to check its connection every 5 minutes or so.
So you can use timer to call connectionstatus() every 5 minutes .
void setup {
timer.setInterval(5*60*1000, connectionstatus);  // check every 5 minutes
