Hi, I am trying to write (using BlynkLib library) and read (using Requests library - I couldn’t figure out, how to read the value from virtual pin using BlynkLib in python; if you know, let me know ! ) from and to multiple virtual pins. Code is written in python, running on Rpi 4B. The BrokenPipeError appears in random times in random functions. I have no idea how to find the origin of the error or how to fix it. I am not sure, if I shoul provide the code here as it is quite long.
I would appreciate any kind of help .Thanks in an advance !
In general, the brockenpipeerror occurs when you try to write data to a pipe or socket that has been disconnected, meaning the other end is no longer listening or connected.
