if data:
msg_type, msg_id, msg_len = struct.unpack(HDR_FMT, data)
if msg_id == 0:
self._close('invalid msg id %d' % msg_id)
break
if msg_type == MSG_RSP:
if msg_id == self._last_hb_id:
self._last_hb_id = 0
elif msg_type == MSG_PING:
self._send(struct.pack(HDR_FMT, MSG_RSP, msg_id, STA_SUCCESS), True)
elif msg_type == MSG_HW or msg_type == MSG_BRIDGE:
data = self._recv(msg_len, MIN_SOCK_TO)
if data:
self._handle_hw(data)
else:
self._close('unknown message type %d' % msg_type)
break
You can see that if the msg_type is different from MSG_RSP, MSG_PING, MSG_HW , MSG_BRIDGE it will fail. So probably you were receiving a MSG_HW_INFO with id 17 and it closed.
The blynk server is sending a message with ID 17 to the python application and the application is reading it via socket but it cannot parse it correctly (probably a bug in the library). Why that message is sent is unknown to me
This example shows how to display custom data on the widget.
In your Blynk App project:
Add a Value Display widget,
bind it to Virtual Pin V2,
set the read frequency to 1 second.
Run the App (green triangle in the upper right corner).
It will automagically call v2_read_handler.
Calling virtual_write updates widget value.
import BlynkLib
import time
BLYNK_AUTH = ‘’
Initialize Blynk
Register virtual pin handler
@blynk.VIRTUAL_READ(2)
def v2_read_handler():
# This widget will show some time in seconds…
blynk.virtual_write(2, time.ticks_ms() // 1000)
