Blynk - Python 3D
Dear all, I’m new to the Community. Let me explain my project:
1- I’m measuring temperature with five DB18b20 sensors.
2- I’ve programmed the code in Wokwi using C.
3- I’ve visualized the temperatures in Blynk.
But I also need to add a link in Blynk to access a 3D graph programmed in Python (to visualize the sensor temperatures).
My question is:
1- How can this work?
2- Do you have a similar example you could share with me?
Thank you for your assistance.
Best regards,
Is this 3D graph published to a webpage that’s publicly accessible?
Hi Pete, the 3D graphic will be on a private website.
I look forward to your kind response
In that case, it won’t be accessible.
If you gave it a publicly resolvable url then you could add a webpage button to Blynk to open that url.
That could be as simple as using a DDNS service and an updater, and opening the appropriate port on your router - assuming you’re comfortable with the security implications of doing that.
