Blynk OTA Token
I installed the Blynk_OTA_Token example, however there is an arduinojson version problem when compiling. I tried to follow the upgrade sketch to version 6 but no luck. Is there a later example available on Github that I have possibly missed?
I’ve never used Blynk OTA, but JSON version issues can be solved easily by downgrading to an earlier version of Arduino JSON in the IDE.
Thanks, I will try that. But I think I was on the older version and then upgraded to V6 in frustration. But let me roll back and see if it solves the problem.
