I’ve connected my esp8266 through wifi just fine using the quick start, but it doesn’t work if connecting a device created from template. when it doesn’t work it alternating between online and offline in the device page, and repeat trying to connect in the serial monitor.
Sketch (sensitive info redacted), is the same when working and when not working, except BLYNK_TEMPLATE_ID, BLYNK_DEVICE_NAME, BLYNK_AUTH_TOKEN, who I copied from the device page when creating new device from template (that’s not working) and from creating new device from quick start (working):
#define BLYNK_TEMPLATE_ID REDACTED
#define BLYNK_DEVICE_NAME REDACTED
#define BLYNK_AUTH_TOKEN REDACTED
char ssid[] = REDACTED;
char pass[] = REDACTED;
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
Output when not working, repeats every 30 seconds:
[4307] Connected to WiFi
[4307] IP: 192.168.0.101
[4307]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.0.1 on ESP8266
[4384] Connecting to blynk.cloud:80
[4831] Redirecting to fra1.blynk.cloud:80
[4833] Connecting to fra1.blynk.cloud:80
⸮⸮⸮Ԝ[71] Connecting to REDACTED
output when working:
[4307]
___ __ __
[5052] Ready (ping: 85ms).
