These are some significant ping times (except the first one, which seems unrealistically low if using Blynk cloud).
What sort of results do you get if you ping blynk-cloud.com from your PC?
Dipping into the admin screens for your user ID shows that you (or at least your ISP) are located in Paris, so you’re in a relatively civilized (at least from a technology point of view
) part of the world.
I’m in London and ping times from my PC vary a bit, but something like is fairly normal:
Pinging blynk-cloud.com [139.59.206.133] with 32 bytes of data:
Reply from 139.59.206.133: bytes=32 time=37ms TTL=55
Reply from 139.59.206.133: bytes=32 time=36ms TTL=55
Ping statistics for 139.59.206.133:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 36ms, Maximum = 37ms, Average = 36ms
We’ll both be hitting the same Blynk cloud server in Frankfurt, so I’d expect something similar for you.
I wonder if you’re seeing issues like those described in this topic:
