Reading this I found out that the backlash had to be escaped in order to be considered as a literal string because otherwise the parser treat it like a special character.
So now the script runs but I’m still not recieving any value on the app…
Are you confirming that data is even getting pulled back into the script, with CLI prints?
No, but I can confirm that the app works and is recieving the “os.time” on pin V2
EDIT:
I confirm, data is getting pulled back into the script with CLI prints!
EUREKA!
#!/usr/bin/env lua
This is the default example for Linux, Windows, OpenWrt
local socket = require("socket")
local use_ssl, ssl = pcall(require, "ssl")
local Blynk = require("blynk.socket")
local Timer = require("timer")
assert(#arg >= 1, "Please specify Auth Token")
local auth = arg[1]
local blynk = Blynk.new(auth, {
heartbeat = 10, -- default h-beat is 30
--log = print,
local function connectBlynk()
local host = "blynk-cloud.com"
local sock = assert(socket.tcp())
sock:setoption("tcp-nodelay", true)
if use_ssl then
print("Connecting Blynk (secure)...")
sock:connect(host, 443)
local opts = {
mode = "client",
protocol = "tlsv1"
sock = assert(ssl.wrap(sock, opts))
sock:dohandshake()
print("Connecting Blynk...")
sock:connect(host, 80)
end
-- tell Blynk to use this socket
blynk:connect(sock)
end
function exec_out(cmd)
local file = io.popen(cmd)
if not file then return nil end
local output = file:read('*all')
file:close()
-- print("Run: "..cmd.." -> "..output)
return output
end
function read_file(path)
local file = io.open(path, "rb")
local content = file:read "*a"
file:close()
-- print("Read: "..path.." -> "..content)
return content
end
function getArpClients()
return tonumber(exec_out('cat /sys/bus/iio/devices/iio\\:device0/in_voltage0_raw'))
end
function getUptime()
return tonumber(exec_out("cat /proc/uptime | awk '{print $1}'"))
end
-- callback to run when V1 changes
blynk:on("V1", function(param)
print("V1:", tonumber(param[1]), tonumber(param[2]))
end)
-- callback to run when cloud requests V2 value
blynk:on("readV2", function(param)
blynk:virtualWrite(2, os.time())
end)
-- create a timer to update widget property
local tmr1 = Timer:new{interval = 5000, func = function()
blynk:virtualWrite(10, getArpClients())
blynk:virtualWrite(11, string.format("%.1f h", getUptime()/60/60))
end}
connectBlynk()
while true do
blynk:run()
tmr1:run()
end
No more unsupported board!
me too
and I ask myself why to use Lua
Well, I am glad you understand whatever solved your issue If you can, would you mind explaining a little bit about what the solution was? Thanks.
Yes, basically as I stated in previuos post
but then, as you can see by my CLI screenshot it wasn’t enough because it seemed that the command was passed correctly but not executed, so that took me a few head bangs and most of the day to figure out why, since copying and pasting manually from the output of the lua script returned the value properly, while executing it didn’t .
In few words reading this carefully and again and again brought me to the not so explicit way of passing the command even without escaping the special char (backlash).
Best solution is to enclose the string inside double square brackets so the parser treats it as non lua code (still can be code for other language, html page for example).
Now I only have to map the voltage that I’m receiving to the sensor depth range and ad few other math calculations before deploying everything in place.
Thanks for now.
Lawrence
