Ok, do you use Android or iOS? Latest version, right?
Yes,
- A BeagleBone White running on Debian hosts the server, with Blynk server release 0.8.0,
- The Blynk version 1.0 RC7 for Android displays the data on a Slate 7 Plus tablet from Hewlett Packard running on Android 4.2.2 .
I think Iāve found what originated the confusion.
When creating a new account on the Blynk app, the e-mail field shall contain the @
and .
characters, and the password shall be populated. Otherwise, the āSomething went wrong? Try laterā cryptic message appears but provides no clue about whatās going wrong.
At the contrary, the client provides a richer feed-back.
15:37:56.993 TRACE - Incoming ResponseMessage{id=6408, command=RESPONSE, responseCode=ILLEGAL_COMMAND}
So my suggestion is, the Blynk app should provide more information about what exactly is expected to create a connection to the local server.
Lol. Good catch. Thank you for reporting. Will fix it.
Hi Avenue33,
Iām planning to use CC3200MOD on my project and I need as much as ADC port I can have. If I can have all 4 of them, then having mux on each, I can still having 4x fast priority ADC, and 4x less priority (occasional reading). But the hardware abstraction (boards_json) only exporting 3 out of 4. Have you tried to just add the ADC_CH0 in and does it work? I presume on the app side this need to be added as wellā¦
Many thanks.
Hello @akm17:
Well, analog inputs on the CC3200 are a mess.
First, maximum voltage is 1.5 V for analog inputs, so check twice before using them! One of my CC3200 I used with a touch-screen was zombified because of that limitation.
Second, analog inputs are in limited number. Iād suggest to use a SPI- or I²C-driven fast ADC with any many inputs you need. You can even use a cheap DIP20 MSP430G2553 for that. The main loop reads the values, processes them and populates the virtual ports with the values. Thatās how I proceeded with my weather and security station.
Good luck with your project!
Can i ask a question.
What does āCC3200 EMTā mean ?
Energia MT = Energia Multi-Tasking, based on TI-RTOS.
See LaunchPad MSP432: RTOS for Everyone and Exploring RTOS with Galaxia on Energia MT.
I posted two projects featuring Blynk on Hackster!
Done. Thank you very much!
