Blynk not working with Adafruit Motorshield V2.3
I have some problems when using Blynk and the Adafruit Motorshield V2.3 on my Arduino Uno R3. I have a HC-05 Bluetooth module to work with Blynk and a stepper motor attached to the Motorshield. I can control the on-board LED via the Blynk app and I can get the stepper motor to rotate when running the test program from Adafruit, however, when I try to combine both so I can control the stepper motor using Bluetooth on my cellphone the motor won’t turn anymore, while I am still able to control the LED.
// BLUETOOTH/BLYNK STUFF #################################
SoftwareSerial DebugSerial(0, 1); // RX, TX
char auth[] = "auth_code";
// ADAFRUIT MOTORSHIELD STUFF ###############################
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
// Create the motor shield object with the default I2C address
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Or, create it with a different I2C address (say for stacking)
// Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x61);
// Connect a stepper motor with 200 steps per revolution (1.8 degree)
// to motor port #2 (M3 and M4)
Adafruit_StepperMotor *myMotor = AFMS.getStepper(200, 2);
  DebugSerial.begin(9600);
  // 9600 is for HC-06. For HC-05 default speed is 38400
  Blynk.begin(Serial, auth);
  AFMS.begin();  // create with the default frequency 1.6KHz
  myMotor->setSpeed(10);  // 10 rpm
BLYNK_WRITE(V1)
  int pinValue = param.asInt();
  if(pinValue == 1)
    myMotor->step(35, FORWARD, SINGLE); //It wont rotate the stepper
    myMotor->release();
    digitalWrite(13, pinValue); //It will execute this line, the LED is on
  }else
//    myMotor->release();
//  myMotor->step(100, FORWARD, SINGLE);
//  myMotor->step(100, BACKWARD, SINGLE);
When commenting out the Blynk.begin(Serial, auth) the two lines in void loop() suddenly start working again…
Thanks in advance
Finally got it working!!!
Apparantly (I do not now why) doesn’t it work when calling Blynk.begin(Serial, auth), but it does work when calling Blynk.config(Serial, auth).
char auth[] = "7fa0ea4720e0427fbd2875cb9c24e280";
#include <Wire.h>
// Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x70);
//  Blynk.begin(Serial, auth);
  Blynk.config(Serial, auth);
BLYNK_WRITE(V1)
  if(pinValue == 1)
    myMotor->release();
  }else
    myMotor->release();
