I’m having a problem with my code, When I do it without blynk it works but when I add blynk it doesn’t work
Here are my codes with and without blynk
WITHOUT BLYNK
int sensor =13;
int buzzer = 0;
int sensorstate= 0;
//button
int buttonPin = 2;
int buttonState=0;
// input 1
int input1 =12; //
int input1state=0;
// input 2
int input2 =14; //
int input2state=0;
//input 3
int input3 =4;
int input3state=0;
int pin=16;
int pins=5;
pinMode(buzzer,OUTPUT);
pinMode(sensor,INPUT);
pinMode(input1,INPUT);
pinMode(input2,INPUT);
pinMode(input3,INPUT);
pinMode(pin,OUTPUT);
pinMode(pins,OUTPUT);
void sensorers(){
sensorstate=digitalRead(sensor);
if (sensorstate==HIGH)
digitalWrite(buzzer,HIGH);
digitalWrite(pin,LOW);
digitalWrite(pins,HIGH);
else{
digitalWrite(buzzer,LOW);
digitalWrite(pin,HIGH);
digitalWrite(pins,LOW);
void callpanicbutton(){
//own loop
buttonState = digitalRead(buttonPin);
void callinput1(){
//own loop
input1state = digitalRead(input1);
void callinput2(){
//own loop
input1state = digitalRead(input2);
void callinput3(){
//own loop
input1state = digitalRead(input3);
sensorers();
callpanicbutton();
callinput1();
callinput2();
callinput3();
WITH BLYNK
//sensors
int sensor =13;
int buzzer = 0;
int sensorstate = 0;
//button
int buttonPin = 2;
int buttonState=0;
//input 1
int input1 =12; //
int input1state=0;
//input 2
int input2 =14;
int input2state=0;
//input 3
int input3 =4;
int input3state=0;
char auth[] = " uEv7YIPD4ytrrx9zFABHqS89vaG9gjro";
char ssid[] = "MBEVA";
char pass[] = "mashimbye";
void myTimerEvent()
//own loop
Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
//Setup a function to be called every second
void sensorers(){
Blynk.notify("MOVEMENT IN THE STORE");
else{
void callinput1(){
//own loop
void callinput2(){
input2state = digitalRead(input2);
void callinput3(){
//own loop
input3state = digitalRead(input3);
sensorers();
callpanicbutton();
callinput1();
callinput2();
callinput3();
