I am having trouble reconnecting, my program sends the data smoothly between 8 and 10 hours but unexpectedly disconnects, I thought using the HEARTBEAT would work but it won’t reconnect, my oled display keeps showing and reading the sensor data normally. I have read in other forums that it should connect normally or try to since the Blynk.run() function takes care of it. I will now try to set the Blynk.connected == false and then Blynk.connect() to check if it works.Do you have any suggestions for reconnections on cards over GPRS or 2G,3G,4G connection?
#define BLYNK_TEMPLATE_ID "sssssssssssssss"
#define BLYNK_TEMPLATE_NAME "xxxxxxxxxxxxxxxxxxx"
#define BLYNK_AUTH_TOKEN "xxxxxxxxxxxxxxxxxxxxx"
// Select your modem:
#define TINY_GSM_MODEM_SIM7600
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// Set serial for AT commands (to the module)
// Use Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial1
// See all AT commands, if wanted
#define DUMP_AT_COMMANDS
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
#define BLYNK_HEARTBEAT 70
#include <TinyGsmClient.h>
#include <Arduino.h>
#include <Wire.h>
#include <SD.h>
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "";
char user[] = "";
char pass[] = "";
#define UART_BAUD 115200
#define MODEM_TX 27
#define MODEM_RX 26
#define MODEM_PWRKEY 4
#define MODEM_DTR 32
#define MODEM_RI 33
#define MODEM_FLIGHT 25
#define MODEM_STATUS 34
#define SD_MISO 2
#define SD_MOSI 15
#define SD_SCLK 14
#define SD_CS 13
#define LED_PIN 12
bool reply = false;
#include <BMx280I2C.h>
#define I2C_ADDRESS 0x76 //sensor de temperatura y humedad para el refri
BMx280I2C bmx280(I2C_ADDRESS);
#include <Adafruit_GFX.h> //pantalla
#include <Adafruit_SH110X.h>
#define i2c_Address 0x3c //initialize with the I2C addr 0x3C Typically eBay OLED's
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // QT-PY / XIAO
Adafruit_SH1106G display = Adafruit_SH1106G(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#include<ADS1115_WE.h>
#include<Wire.h>
#define I2C_ADDRESS_1 0x48// para los voltajes
#define I2C_ADDRESS_2 0x49// para otros
ADS1115_WE adc_1 = ADS1115_WE(I2C_ADDRESS_1);
ADS1115_WE adc_2 = ADS1115_WE(I2C_ADDRESS_2);
//AHT10 0x38 el azul
//bmp280 0x76 el morado
//HTU12D 0x40 el rojo el otro azul tambien es 0x40
#include <Wire.h>
#include "Adafruit_HTU21DF.h"
Adafruit_HTU21DF htu = Adafruit_HTU21DF();
const int buzzerPin = 33; // Pin del buzzer
BLYNK_CONNECTED()
Blynk.syncVirtual(V0); // will cause BLYNK_WRITE(V3) to be executed
delay(200);
Blynk.syncVirtual(V1);
delay(200);
Blynk.syncVirtual(V2);
delay(200);
Blynk.syncVirtual(V3);
delay(200);
Blynk.syncVirtual(V4);
delay(200);
Blynk.syncVirtual(V5);
delay(200);
Blynk.syncVirtual(V6);
delay(200);
Blynk.syncVirtual(V7);
delay(200);
Blynk.syncVirtual(V8);
delay(200);
Blynk.syncVirtual(V9);
delay(200);
Blynk.syncVirtual(V10);
delay(200);
float data_1_adc;
float data_2_adc;
float data_3_adc;
float data_4_adc;
float data_5_adc;
float data_6_adc;
float temp_ext;
float hum_ext;
float temp_int;
float hum_int;
float VPanel;
float VBatt;
float cototalSubAC;
float corrienBatteria;
float CoPanel;
float VoltAC;
float temp1;
float temp2;
float hum1;
float hum2;
float vibracion1;
float vibracion;
float vibracionD;
//#define Voltaje_bateria 32 // pin del sensor de corriente bateria
//#define Voltaje_Panel 34
#define FILTER_LEN 15
uint32_t AN_Pot1_Buffer[FILTER_LEN] = {0};
int AN_Pot1_i = 0;
int AN_Pot1_Raw = 0;
int AN_Pot1_Filtered = 0;
uint32_t AN_Pot2_Buffer[FILTER_LEN] = {0};
int AN_Pot2_i = 0;
int AN_Pot2_Raw = 0;
int AN_Pot2_Filtered = 0;
void sendSensor()
if(measure_environment_ADC1()){
Serial.print("ADC_1 Comp 0-1: ");
Serial.println(data_1_adc);
VPanel=data_1_adc;
delay(100);
if(measure_environment_ADC2()){
Serial.print("ADC_1 Comp 2-3: ");
Serial.println(data_2_adc);
VBatt=data_2_adc;
delay(100);
if(measure_environment_ADC3()){
Serial.print("ADC_2 Comp 0-GND: ");
Serial.println(data_3_adc);
cototalSubAC= data_3_adc;
delay(100);
if(measure_environment_ADC4()){
Serial.print("ADC_2 Comp 1-GND: ");
Serial.println(data_4_adc);
corrienBatteria=data_4_adc;
delay(100);
if(measure_environment_ADC5()){
Serial.print("ADC_2 Comp 2-GND: ");
Serial.println(data_5_adc);
CoPanel=data_5_adc;
delay(100);
if(measure_environment_ADC6()){
Serial.print("ADC_2 Comp 3-GND: ");
Serial.println(data_6_adc);
VoltAC=data_6_adc;
delay(100);
float temRefrigerador;
float humRefrigerador;
float temAmbiente;
float humAmbiente;
if (measure_environment2()) {
Serial.print("T2 = ");
Serial.print(temp_ext, 2);
temp1=temp_ext;
Serial.print(" deg. C, H2 = ");
Serial.print(hum_ext, 2);
hum1= hum_ext;
Serial.println("%");
delay(100);
if (measure_environment1()) {
Serial.print("T1 = ");
Serial.print(temp_int, 2);
temp2= temp_int;
Serial.print(" deg. C, H1 = ");
Serial.print(hum_int, 2);
hum2= hum_int;
delay(100);
delay(100);
display.clearDisplay();
drawdata();
display.display();
delay(2000);
delay(100);
if (temp1 > 40){
alarma();
if (temp2 > 10){
alarma();
Blynk.virtualWrite(V0, temp1);
delay(200);
Blynk.virtualWrite(V1, hum1);
delay(200);
Blynk.virtualWrite(V2, temp2);
delay(200);
Blynk.virtualWrite(V3, hum2);
delay(200);
Blynk.virtualWrite(V4,VBatt);
delay(200);
Blynk.virtualWrite(V5,CoPanel);
delay(200);
Blynk.virtualWrite(V6,VPanel);
delay(200);
Blynk.virtualWrite(V7,VoltAC);
delay(200);
Blynk.virtualWrite(V8,cototalSubAC);
delay(200);
Blynk.virtualWrite(V9,corrienBatteria);
delay(200);
Blynk.virtualWrite(V10,12);
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(SerialAT, SerialMon);
TinyGsm modem(debugger);
#else
TinyGsm modem(SerialAT);
#endif
// Set console baud rate
SerialMon.begin(115200);
//begin() checks the Interface, reads the sensor ID (to differentiate between BMP280 and BME280)
while (!Serial);
pinMode(buzzerPin,OUTPUT);
Wire.begin();
delay(400); // wait for the OLED to power up
display.begin(i2c_Address, true); // Address 0x3C default
//display.setContrast (0); // dim display
display.display();
delay(2000);
// Clear the buffer.
if (!bmx280.begin())
Serial.println("begin() failed. check your BMx280 Interface and I2C Address.");
while (1);
if (bmx280.isBME280())
Serial.println("sensor is a BME280");
Serial.println("sensor is a BMP280");
//reset sensor to default parameters.
bmx280.resetToDefaults();
//by default sensing is disabled and must be enabled by setting a non-zero
//oversampling setting.
//set an oversampling setting for pressure and temperature measurements.
bmx280.writeOversamplingPressure(BMx280MI::OSRS_P_x16);
bmx280.writeOversamplingTemperature(BMx280MI::OSRS_T_x16);
//if sensor is a BME280, set an oversampling setting for humidity measurements.
bmx280.writeOversamplingHumidity(BMx280MI::OSRS_H_x16);
//set the sensor to "normal" mode with 4 measurement per second:
bmx280.writeStandbyTime(BMx280MI::T_SB_3);
bmx280.writePowerMode(BMx280MI::BMx280_MODE_NORMAL);
if(!adc_1.init()){
Serial.print("ADS1115 No 1 not connected!");
adc_1.setVoltageRange_mV(ADS1115_RANGE_6144);
adc_1.setMeasureMode(ADS1115_CONTINUOUS);
adc_1.setCompareChannels(ADS1115_COMP_0_GND);
adc_1.setCompareChannels(ADS1115_COMP_2_GND);
if(!adc_2.init()){
Serial.print("ADS1115 No 2 not connected!");
adc_2.setVoltageRange_mV(ADS1115_RANGE_6144);
adc_2.setMeasureMode(ADS1115_CONTINUOUS);
adc_2.setCompareChannels(ADS1115_COMP_0_GND);
adc_2.setCompareChannels(ADS1115_COMP_1_GND);
adc_2.setCompareChannels(ADS1115_COMP_2_GND);
adc_2.setCompareChannels(ADS1115_COMP_3_GND);
//voltageSensor.setSensitivity(SENSITIVITY);
// Set GSM module baud rate
SerialAT.begin(UART_BAUD, SERIAL_8N1, MODEM_RX, MODEM_TX);
The indicator light of the board can be controlled
pinMode(LED_PIN, OUTPUT);
digitalWrite(LED_PIN, HIGH);
MODEM_PWRKEY IO:4 The power-on signal of the modulator must be given to it,
otherwise the modulator will not reply when the command is sent
pinMode(MODEM_PWRKEY, OUTPUT);
digitalWrite(MODEM_PWRKEY, HIGH);
delay(300); //Need delay
digitalWrite(MODEM_PWRKEY, LOW);
MODEM_FLIGHT IO:25 Modulator flight mode control,
need to enable modulator, this pin must be set to high
pinMode(MODEM_FLIGHT, OUTPUT);
digitalWrite(MODEM_FLIGHT, HIGH);
//Initialize SDCard
SPI.begin(SD_SCLK, SD_MISO, SD_MOSI, SD_CS);
if (!SD.begin(SD_CS)) {
Serial.println("SDCard MOUNT FAIL");
uint32_t cardSize = SD.cardSize() / (1024 * 1024);
String str = "SDCard Size: " + String(cardSize) + "MB";
Serial.println(str);
if (!modem.restart()) {
Serial.println("Failed to restart modem, attempting to continue without restarting");
String name = modem.getModemName();
delay(500);
Serial.println("Modem Name: " + name);
delay(5000);
timer.setInterval(2000L, sendSensor);
// Setup pin for intterrupt
if (Blynk.connected()){
Blynk.connect();
BLYNK_CONNECTED();
static bool measure_environment2() {
static unsigned long measurement_timestamp = millis();
// Measure once every four seconds.
if (millis() - measurement_timestamp > 2000ul) {
if(htu.begin()){
temp_int = htu.readTemperature();
hum_int = htu.readHumidity();
return (true);
}else{
alarma();
temp_int = 250.0;
hum_int = 250.0;
return(true);
return (false);
static bool measure_environment1() {
if (millis() - measurement_timestamp > 1000ul) {
if(bmx280.begin()){
if(!bmx280.measure()){
Serial.println("could not start measurement, is a measurement already running?");
return(true);
do{
delay(100);
}while(!bmx280.hasValue());
long da1= bmx280.getPressure();
long da2= bmx280.getPressure64();
long da3= bmx280.getPressureI64();
temp_ext=bmx280.getTemperature();
if (bmx280.isBME280()){
hum_ext=bmx280.getHumidity();
if(isnan(temp_ext) && isnan(hum_ext)){
alarma();
return (true);
}else{
temp_ext = 250.0;
hum_ext = 250.0;
alarma();
return(true);
return (false);
float readChannel1(ADS1115_MUX channel) {
float voltage = 0.0;
adc_1.setCompareChannels(channel);
voltage = adc_1.getResult_mV(); // alternative: getResult_mV for Millivolt
return voltage;
float readChannel2(ADS1115_MUX channel) {
adc_2.setCompareChannels(channel);
voltage = adc_2.getResult_mV(); // alternative: getResult_mV for Millivolt
return voltage;
static bool measure_environment_vibracion() {
//vibracion1=analogRead(32);
//vibracionD=digitalRead(34);
return (true);
return (false);
static bool measure_environment_ADC1() {
data_1_adc=readChannel1(ADS1115_COMP_0_GND);
return (true);
return (false);
static bool measure_environment_ADC2() {
data_2_adc=readChannel1(ADS1115_COMP_2_GND);
return (true);
return (false);
static bool measure_environment_ADC3() {
data_3_adc=readChannel2(ADS1115_COMP_0_GND);
return (true);
return (false);
static bool measure_environment_ADC4() {
data_4_adc=readChannel2(ADS1115_COMP_1_GND);
return (true);
return (false);
static bool measure_environment_ADC5() {
data_5_adc=readChannel2(ADS1115_COMP_2_GND);
return (true);
return (false);
static bool measure_environment_ADC6() {
data_6_adc=readChannel2(ADS1115_COMP_3_GND);
return (true);
return (false);
void drawdata(){
display.setTextSize(2);
display.setTextColor(SH110X_WHITE);
display.setCursor(0, 0);
display.print("TAm:");display.print(temp1); display.println("C");
display.print("TRe");display.print(temp2);display.println("C");
display.print("HAm:");display.print(hum1); display.println("%");
display.print("HRe");display.print(hum2);display.println("%");
display.display();
delay(1);
void alarma(){
tone(buzzerPin,660,250);
// Esperar 0.5 segundos
delay(500);
// Apagar el buzzer
//digitalWrite(buzzerPin, LOW);
why my code looks weird?
