Blynk not connect on WiFI
I am trying to connect to network, My hardware is Arduino Uno + WiFi Shield.
Tryng the wifi code, the console output is still on connecting state:
[82] Connecting to MyNetworkNane
[10117] IP: 192.168.0.214
[21139] Connecting to blynk-cloud.com:8442
[31140] Connecting to blynk-cloud.com:8442
and ready never appears. It seems wifi connection is done but network acces to blynk server not.
If I try telnet by mac terminal to :
telnet blynk-cloud 8442
connected appear:
Trying 139.59.206.133…
Connected to blynk-cloud
My network access is by ADSL router. Do I need any configuration ?
@Domenico_Sicignano repeated Connecting to … messages may mean a bad token.
Did you enter a valid token in the sketch?
Paste your formatted sketch without your confidential details like token and router access.
Thanks to replay.
My sketch
#include <WiFi.h>
#include <BlynkSimpleWifi.h>
char auth[] = "1cfa1e**********ae7b2cc1";
char ssid[] = "Vodafone****";
char pass[] = "aHwK******dBNY";
  //Blynk.begin(auth, ssid, pass);
  Blynk.begin(auth, ssid, pass, IPAddress(139,59,206,133), 8442);
I try both
and
@Domenico_Sicignano you have a very bad system for Blynk, almost as bad as Uno with ESP-01.
Have you updated the firmware on the Uno WiFi ?
Study [Solved] Arduino.org Uno WiFi board with Firmware 1.0.0 and WiFiLink.h Librairies
I just update firmaware but not change.
The shield is connected to wifi network ( ping respond), but no connected to blynk server.
Did you make all the changes covered in the link I provided?
I am not sure about how do:
Have I modify the BlynkSimpleWifi.h file in library?
Read the whole thread a few times and then concentrate on the posts from [Solved] Arduino.org Uno WiFi board with Firmware 1.0.0 and WiFiLink.h Librairies onwards.
ok thanks. But Did you experimented the same problem in the past?
No I wouldn’t be seen dead with that hardware setup, $3 to $5 plug and play ESP8266 boards for me.
LOL :slight_smile:
