Blynk Multi ESP8266 with Manual and Timer controls not working right
I am new to Blynk and am having a little trouble with my setup. I have uploaded the wiring drawing of my two ESP8266 (NodeMCUs) and will include the code as well. I have done something wrong somewhere. If anyone can provide help or at least another set of eyes to help me solve this it would be great. My idea is to use the same auth code for both devices and use just one project screen to control both sets of lights on outlets. The manual control is working fine on the single relay unit. The dual relay unit I think I am getting some feedback on my wiring or something as it shuts off if I have something plugged in. The timer function used to work, but does not seem to want to work now as well on either one. I will post the code below. Also in the picture I have included the Blynk app icons and what ports they are assigned to as well. Thank you very much for any help that is provided.
//ESP8266 #1 Script
//int enableTimer = HIGH;
int timer1Running = LOW;
int manualOffice = LOW;
char auth[] = "Code";
void checkTimer();
  Blynk.begin(auth, "SID", "Pass");
  timer.setInterval(2000, checkTimer);
  pinMode(14, OUTPUT);
  digitalWrite(14, LOW);
/*BLYNK_WRITE(9){
  enableTimer = param.asInt();
BLYNK_WRITE(10){
  timer1Running = param.asInt();
BLYNK_WRITE(11){
  manualOffice = param.asInt();
BLYNK_WRITE(14)
BLYNK_LOG("Timer Value (V14): %s", param.asStr());
  timer.run();  //  call function
void checkTimer()
  // If timer is running or if manual override is on turn lights on
  if(((timer1Running == 1)) || (manualOffice == 1))
  //if(((enableTimer == 1) && (timer1Running == 1)) || (manualOffice == 1))
    // Timer is running, so lights on!
    digitalWrite(14, HIGH); //
    Blynk.virtualWrite(19, 1023);  // Turns Virtual LED on to signify on Phone that the light was indeed turned on.
    digitalWrite(14, LOW);  //
    Blynk.virtualWrite(19, 0);     // Turns Virtual LED off to signify on Phone that the light was indeed turned off.
//ESP8266 #2 Script
int timer2Running = LOW;
int manualLight1 = LOW;
int manualLight2 = LOW;
void checkTimer();
  pinMode(4, OUTPUT);
  digitalWrite(4, LOW);
  pinMode(5, OUTPUT);
  digitalWrite(5, LOW);
BLYNK_WRITE(3){
BLYNK_WRITE(30){
  timer2Running = param.asInt();
BLYNK_WRITE(25){
  manualLight1 = param.asInt();
BLYNK_WRITE(16){
  manualLight2 = param.asInt();
BLYNK_WRITE(4)
BLYNK_LOG("Timer Value (V4): %s", param.asStr());
void checkTimer()
  if(((timer2Running == 1)) || (manualLight1 == 1))
    digitalWrite(4, HIGH); //
    //digitalWrite(5, HIGH);
    Blynk.virtualWrite(20, 1023);  // Turns Virtual LED on to signify on Phone that the light was indeed turned on.
    //digitalWrite(5, LOW);
    Blynk.virtualWrite(20, 0);     // Turns Virtual LED off to signify on Phone that the light was indeed turned off.
  if(((timer2Running == 1)) || (manualLight2 == 1))
    Blynk.virtualWrite(21, 1023);  // Turns Virtual LED on to signify on Phone that the light was indeed turned on.
    digitalWrite(5, LOW);//
    Blynk.virtualWrite(21, 0);    // Turns Virtual LED off to signify on Phone that the light was indeed turned off.
I am using a different brand relay board, but I found that the 3.3v output from the ESPs pins did not provide enough power. I had to use a level shift to get supply the relay board with 5v trigger inputs. Good luck!
Thanks for the comment, if you notice I am using a level shift up to 5.2V on the top drawing. On the bottom drawing, I am using a 5.2 V USB cord and the Nodemcu board provides the 5.2V on the bottom left pin to the relays. I am able to do the manual buttons in blink just fine. It just seems that something with the timer code is not working correctly. What is really strange, is that the timer works on one of the boards as of this morning but not on the other one.
I also modified my wiring this morning on the top drawing because I believe I am getting some feedback from energizing the relays. I removed the two voltage converters from the circuit and am powering the NodeMCU via USB instead. It seems to be working as expected but I now cant have just one plug coming out of the receptacle like I wanted. I am trying to make this system only have one power plug come out and allow control of two outlets.
The drawing shows you supplying the Vin on each board with 5v. However the ESP only outputs 3.3v to the relay trigger pins. In my experience, I had unreliable relay actions with 3.3v trigger even though I was supplying 5v to the relay board’s Vin. I had to put in a level shifter in between the relay board and the ESP output pins.
I see that the manual buttons work as expected so it’s probably not the power thing I’m mentioning. Just keep it in mind when troubleshooting.
Vin also happens to be Vout when using USB. I measured the voltage and it is 5V. My problem isn’t getting the relays to work. I can control them great with the manual on off buttons in Blynk. I also was able to control them fine with the timer although flaky before but has stopped recently on one of the bottom drawing.
Thank you for your help, I do appreciate it.
No problem :slight_smile: best of luck
so you have some wiring issues?
can you post actual pic of setup?
is it soldered or breadboard?
I’ll see about doing it later today, I am at work so I can’t right now. It is wired as the pictures show. It is the top one that I have had the issues with. I am thinking that I need to insert either diodes or resistors to limit the direction of the electricity.
Edit: I did a combo of soldering and bread board.
i think the relay boards have these already?
it ‘used to work’ implies something has changed.
if YOU haven’t changed anything, then something changed itself
Yes the Relays do, but I think I might be getting some feedback on the power lines that are used to power the NodeMCU. This is what Script 2 looks like wired up currently with a working timer as of this morning without the voltage converters.
Script 1 the time does not work correctly and wiring is fine for what its purpose is for.
I forgot to take a picture last night. Does anyone see any problem with using this code instead of what I posted earlier? I am at work and cannot test it as of right now.
char auth[] = "Auth";
  pinMode(0, OUTPUT);
  digitalWrite(0, LOW);
  pinMode(13, OUTPUT);
  digitalWrite(13, LOW);
BLYNK_WRITE(V3)
  /* Widget button set to turn on/off on GPIO0
     You'll get HIGH/1 at startTime and LOW/0 at stopTime.
     this method will be triggered every day
     until you remove widget or stop project or
     clean stop/start fields of widget
  BLYNK_LOG("Got a value: %s", param.asStr());
  if((timer1Running == 1))
    digitalWrite(0, HIGH); //
    Blynk.virtualWrite(13, 1023);
    Blynk.virtualWrite(13, 0);
BLYNK_WRITE(V7)
  /* Widget button set to turn on/off on GPIO13
  if((timer2Running == 1))
    digitalWrite(13, HIGH); //
    Blynk.virtualWrite(17, 1023);
    Blynk.virtualWrite(17, 0);
OK, so I changed it even more possibly cleaned up the problem from the very first part of code. Please check this and see if you see anything. Thank you all.
int timer1Manual = LOW;
int timer2Manual = LOW;
  pinMode(0, OUTPUT);
BLYNK_WRITE(V3)
     clean stop/start fields out of widget
    Blynk.virtualWrite(23, 1023);
    Blynk.virtualWrite(23, 0);
BLYNK_WRITE(V13)
  //Manualy Turn on light
  timer1Manual = param.asInt();
BLYNK_WRITE(V7)
    Blynk.virtualWrite(27, 1023);
    Blynk.virtualWrite(27, 0);
BLYNK_WRITE(V17)
  timer2Manual = param.asInt();
  timer1();
  timer2();
void timer1()
  if((timer1Running == 1) || (timer1Manual == 1))
    // Timer is running and enabled or manual turned on, so lights on!
    Blynk.virtualWrite(23, 1023);  // Turns Virtual LED widget on currently assigned to Virtual Pin 23
    digitalWrite(0, LOW);  // Turns lights off
    Blynk.virtualWrite(23, 0);  // Turns virtual LED widget on currently assigned to Virtual Pin 23
void timer2()
  if((timer2Running == 1) || (timer2Manual == 1))
    Blynk.virtualWrite(27, 1023);  // Turns Virtual LED widget on currently assigned to Virtual Pin 27
    digitalWrite(13, LOW);  // Turns lights off
    Blynk.virtualWrite(27, 0);  // Turns virtual LED widget on currently assigned to Virtual Pin 27
this code will definitely not work as it will flood server.
So what would not flood it then?
Look in your function your “if” statement goes through and you are flooding server every loop because Blynk.virtualWrite() would happen on every loop. Rather than that you should switch something ON and thats it stop switching something that is already switched. How is it done? Through callbacks etc. Easiest solution here? Wrap both timers in one func like so and add bool value of shouldSwitch if it’s true you switch virtualPin and GPIO:
void timer1()
 if (shouldSwitch) {
  if((timer1Running) || (timer1Manual))
  if((timer2Running) || (timer2Manual))
  } shouldSwitch = false;
Ok next thing obviously only put timer1() inside loop(), now on every BLYNK_WRITE() add shouldSwitch = true;
Get rid of “if” inside your BLYNK_WRITE(V7) and BLYNK_WRITE(V3) and this will work.
OK, I will check it out thanks for the input.
So I was able to get the manual switches to work just as they were before but the timers are not working with it still.
bool shouldSwitch = false;
char auth[] = "auth code";
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
BLYNK_WRITE(V3)
BLYNK_WRITE(V13)
BLYNK_WRITE(V7)
BLYNK_WRITE(V17)
  timer1();
void timer1()
 if (shouldSwitch) {
    digitalWrite(4, LOW);  // Turns lights off
    digitalWrite(5, LOW);  // Turns lights off
