Thanks for the response,
both lat and lon are floating point
float lat = 0.0, lon = 0.0;
my function to update GPS
void getGPS()
Blynk.virtualWrite(V100, "Getting GPS...");
if (modem.getGPS(&lat, &lon))
Serial.printf("lat:%f lon:%f\n", lat, lon);
if (lat != 0 && lon != 0)
Blynk.virtualWrite(V100, "GPS LOCKED");
Blynk.virtualWrite(V10, lon, lat);
Serial.println("GETTING GPS...");
Blynk.virtualWrite(V11, lat);
Blynk.virtualWrite(V12, lon);
my switch case:
void action()
switch (pinVal)
case 0:
Serial.println("All Functions Off!");
Blynk.virtualWrite(V100, "ALL FUNCTION OFF");
Serial.printf("lat:%f lon:%f\n", 0.0, 0.0);
Blynk.virtualWrite(V11, 0);
Blynk.virtualWrite(V12, 0);
break;
case 1:
getGPS();
break;
Here is a screen shot of my web dashboard:
@PeteKnight The data stream is a “GPS location” as that seems to be the only datastream that the map will take. I have the datastream for location as virtual pin V10.
I am writing to V10 with this code snippet:
There are not may options that I am seeing as far as configuring goes in the settings, am I missing something?
It says that it wants lat and lon in ‘double’ and in the example only shows values out to 4 decimals.
Maybe I need to make them double??
thanks
Here is my code in entirety if that helps. It is not perfect but it is working in every regard except an accurate GPS.
#include <Arduino.h>
http://twitter.com/blynk_app
Attention! Please check out TinyGSM guide:
https://tiny.cc/tinygsm-readme
Change GPRS apm, user, pass, and Blynk auth token to run :)
/* Fill-in your Template ID (only if using Blynk.Cloud) */
// #define BLYNK_TEMPLATE_ID ""
// #define BLYNK_DEVICE_NAME ""
// #define BLYNK_AUTH_TOKEN "";
#define BLYNK_TEMPLATE_ID "********"
#define BLYNK_TEMPLATE_NAME "ESP32 SIM7000"
#define BLYNK_AUTH_TOKEN "*********"
// Select your modem:
#define TINY_GSM_MODEM_SIM7000
Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 5
#include <TinyGsmClient.h>
#include <Wire.h>
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "hologram";
char user[] = "";
char pass[] = "";
#define SerialAT Serial1
#define UART_BAUD 115200
#define PIN_DTR 25
#define PIN_TX 27
#define PIN_RX 26
#define PWR_PIN 4
#define LED_PIN 12
#define BAT_ADC 35
bool reply = false;
int pinVal;
TinyGsm modem(SerialAT);
BLYNK_WRITE(V3)
int pinVal = param.asInt();
if (pinVal == 1)
digitalWrite(LED_PIN, LOW);
digitalWrite(LED_PIN, HIGH);
Serial.println(pinVal);
// Syncing the output state with the app at startup
BLYNK_CONNECTED()
Blynk.syncVirtual(V0);
Blynk.syncVirtual(V2);
Blynk.syncVirtual(V3);
Blynk.syncVirtual(V10);
Blynk.syncVirtual(V11);
Blynk.syncVirtual(V12);
Blynk.syncVirtual(V100);
////////////////////////////////////////// FUNCTIONS //////////////////////////////////////////////////////////////////////////
void getGPS()
BLYNK_WRITE(V0)
void action()
switch (pinVal)
case 0:
break;
case 1:
getGPS();
pinVal = pinVal;
break;
float readBattery(uint8_t pin)
int vref = 1100;
uint16_t volt = analogRead(pin);
float battery_voltage = ((float)volt / 4095.0) * 2.0 * 3.3 * (vref);
return battery_voltage;
void batteryLevel()
float mv = readBattery(BAT_ADC);
Serial.print("mv :");
Serial.println(mv);
Blynk.virtualWrite(V2, ((mv / 4200) * 100));
//////////////////////////////////////////// SET UP //////////////////////////////////////////////////////////////////////////////
Serial.begin(115200); // Set console baud rate
delay(100);
// Set LED OFF
pinMode(LED_PIN, OUTPUT);
pinMode(PWR_PIN, OUTPUT);
digitalWrite(PWR_PIN, HIGH);
delay(300);
digitalWrite(PWR_PIN, LOW);
Serial.println("\nPlease Wait...");
SerialAT.begin(UART_BAUD, SERIAL_8N1, PIN_RX, PIN_TX);
if (!modem.init())
Serial.println("Failed to initialize modem, attempting to continue with restarting");
modem.restart();
String name = modem.getModemName();
delay(500);
Serial.println("Modem Name: " + name);
modem.sendAT("+SGPIO=0,4,1,1"); // Turns on active antenna for GPS
while (modem.waitResponse(10000L) != 1)
Serial.println(" GPS NOT Powered ");
delay(50);
Serial.println("GPS Antenna Powered!");
while (!modem.enableGPS()) // Turns on GPS
Serial.println("GPS not activacted, trying again...");
delay(50);
Serial.println("GPS ACTIVATED!");
// Setup a functions to be called
timer.setInterval(10000L, batteryLevel);
timer.setInterval(3000L, action);
//////////////////////////////////////// MAIN LOOP /////////////////////////////////////////////////////////////////////
