I want to stop sending alerts when itโs over 70 and I tried this code.
Did I miss something?
Code :
void alert(){ if (dht.readHumidity() < 70);{ Blynk.logEvent("moisalert", "Humidity Low"); Serial.println("Humidity Low"); } }
Code :
More information required.
when the humidity over 70% it still send alert to me
#define BLYNK_TEMPLATE_ID "TMPL1ZBP7FMf"
#define BLYNK_DEVICE_NAME "MUSHROOM"
#define BLYNK_AUTH_TOKEN "***************"
#include <DHT.h>
#include <DHT_U.h>
char ssid[] = "********";
char pass[] = "********";
#define DHTPIN D2
#define DHTTYPE DHT11
#define relay D1
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
Serial.println(dht.readHumidity());;
dht.begin();
timer.setInterval(60000L, alert);
pinMode(relay, OUTPUT);
BLYNK_WRITE(V1)
int button = param.asInt();
if (button == 1){
digitalWrite(relay, HIGH);
Serial.println(button);
else if (button == 0){
digitalWrite(relay, LOW);
void alert(){
What does your serial monitor show?
It would help if you took one reading, and stored this in a global variable, then used this reading whenever you are printing out the humidity and doing any if
comparisons.
On another note, there is a limit of 100 events (and therefore a maximum of 100 notifications) per 24 hour period.
Your current process could use up all of that allocation in 100 minutes.
Also, please copy/paste serial output, and use triple backticks at the beginning and end, rather than posting screenshots.
Thanks !I will try it
Your printout says your HUM is โ70.00โ.
Iโd say that any value in the range [69.995 - 70.005] would be printed as 70.00.
From this, iโd say your comparison โ<70โ could easily evaluate to TRUE for a HUM value of 69.995, but be printed as 70.00. (and you also print and compare from different readings)
// I donโt know the resolution of your humidity sensor, but dealing with float values often means you can have values like 70.00001, etc.
Try to evaluate with โ<70.00โ instead.
And - take the hum reading in the alert() function and print THIS value to the serial AND compare with this same reading (not 2 different readings.)
