First time setting up a local server on my raspberry pi 3, I got it up and running but am getting an error when sending an email token:
Notification error. Try again later
I have double checked my gmail app password is correct, i have 2 step authentication on as I couldn’t get one generated without it.
I have:
home/pi/server-0.41.3-java8.jar
home/pi/Blynk/mail.properties
mail.properties consists of:
mail.smtp.auth=true
mail.smtp.starttls.enable=true
mail.smtp.host=smtp.gmail.com
mail.smtp.port=587
mail.smtp.username=zzz@gmail.com
mail.smtp.password=xxxxxxxxxxxx
where zzz is my email edited to stop spam
and xxxxxxxxxx is my google generated app password.
I don’t have a server.properties file as I’m not sure if I need it/what to do.
Here is my log file
09:28:31.464 INFO - Using data dir '/home/pi/Blynk'
09:28:31.956 INFO - Region : local. Host : 192.168.1.95.
09:28:33.713 INFO - Initializing gmail smtp mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
09:28:34.609 INFO - Reports : 0
09:28:34.610 INFO - Didn't find custom user certificates.
09:28:34.615 INFO - Didn't find Let's Encrypt certificates.
09:28:34.615 WARN - You didn't specified 'server.host' or 'contact.email' properties in server.properties file. Automatic certificate generation is turned off. Please specify above properties for automatic certificates retrieval.
09:28:34.615 WARN - ATTENTION. Server certificate paths (cert : '/home/pi', key : '/home/pi') not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
09:28:36.563 INFO - HTTP API and WebSockets server listening at 8080 port.
09:28:36.568 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
09:28:36.570 INFO - Mqtt hardware server listening at 8440 port.
14:03:39.866 INFO - Using data dir '/home/pi/Blynk'
14:03:42.123 INFO - Region : local. Host : eth0.
14:03:43.737 INFO - Initializing gmail smtp mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
14:03:43.834 INFO - Reports : 0
14:03:43.835 INFO - Didn't find custom user certificates.
14:03:43.839 INFO - Didn't find Let's Encrypt certificates.
14:03:43.839 WARN - You didn't specified 'server.host' or 'contact.email' properties in server.properties file. Automatic certificate generation is turned off. Please specify above properties for automatic certificates retrieval.
14:03:43.839 WARN - ATTENTION. Server certificate paths (cert : '/home/pi', key : '/home/pi') not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
14:03:45.129 INFO - HTTP API and WebSockets server listening at 8080 port.
14:03:45.134 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
14:03:45.136 INFO - Mqtt hardware server listening at 8440 port.
14:28:44.099 INFO - Using data dir '/home/pi/Blynk'
14:28:46.280 INFO - Region : local. Host : eth0.
14:28:47.899 INFO - Initializing gmail smtp mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
14:28:48.010 INFO - Reports : 0
14:28:48.011 INFO - Didn't find custom user certificates.
14:28:48.015 INFO - Didn't find Let's Encrypt certificates.
14:28:48.015 WARN - You didn't specified 'server.host' or 'contact.email' properties in server.properties file. Automatic certificate generation is turned off. Please specify above properties for automatic certificates retrieval.
14:28:48.015 WARN - ATTENTION. Server certificate paths (cert : '/home/pi', key : '/home/pi') not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
14:28:49.397 INFO - HTTP API and WebSockets server listening at 8080 port.
14:28:49.402 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
14:28:49.404 INFO - Mqtt hardware server listening at 8440 port.
14:33:57.434 WARN - User 'zzz@gmail.com' not registered. /192.168.1.62:59643
14:34:00.551 WARN - User 'zzz@gmail.com' not registered. /192.168.1.62:59644
14:48:08.733 INFO - Using data dir '/home/pi/Blynk'
14:48:10.841 INFO - Region : local. Host : eth0.
14:48:12.432 INFO - Initializing gmail smtp mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
14:48:12.529 INFO - Reports : 0
14:48:12.530 INFO - Didn't find custom user certificates.
14:48:12.534 INFO - Didn't find Let's Encrypt certificates.
14:48:12.534 WARN - You didn't specified 'server.host' or 'contact.email' properties in server.properties file. Automatic certificate generation is turned off. Please specify above properties for automatic certificates retrieval.
14:48:12.535 WARN - ATTENTION. Server certificate paths (cert : '/home/pi', key : '/home/pi') not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
14:48:14.040 INFO - HTTP API and WebSockets server listening at 8080 port.
14:48:14.044 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
14:48:14.046 INFO - Mqtt hardware server listening at 8440 port.
14:50:16.894 INFO - Trying register user : zzz@gmail.com, app : Blynk
14:50:16.919 INFO - Registered zzz@gmail.com.
14:50:17.108 INFO - zzz@gmail.com Blynk-app (iOS-22500) joined.
14:50:17.722 WARN - Error sending greeting email for zzz@gmail.com.
14:52:06.976 INFO - Creating new dashboard.
14:52:07.463 ERROR- Error sending email auth token to user : zzz@gmail.com. Error: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials o5sm16588254wrv.70 - gsmtp
14:53:37.853 ERROR- Error sending email auth token to user : zzz@gmail.com. Error: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials n189sm2519335wmb.28 - gsmtp
14:55:25.800 INFO - zzz@gmail.com trying to reset pass.
14:55:25.802 INFO - Adding token for zzz@gmail.com user to the pool
14:55:25.810 INFO - Sending token to zzz@gmail.com address
14:55:26.141 INFO - Error sending mail for zzz@gmail.com. Reason : 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials u17sm29566704wrg.71 - gsmtp
14:56:26.902 INFO - zzz@gmail.com trying to reset pass.
14:56:26.902 INFO - Adding token for zzz@gmail.com user to the pool
14:56:26.903 INFO - Sending token to zzz@gmail.com address
14:56:27.268 INFO - Error sending mail for zzz@gmail.com. Reason : 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials y8sm7766836wrm.8 - gsmtp
14:57:52.309 INFO - Trying register user : zzz@gmail.com, app : Blynk
14:57:52.309 WARN - User with email zzz@gmail.com already exists.
14:58:01.930 INFO - zzz@gmail.com trying to reset pass.
14:58:01.930 INFO - Adding token for zzz@gmail.com user to the pool
14:58:01.931 INFO - Sending token to zzz@gmail.com address
14:58:02.340 INFO - Error sending mail for zzz@gmail.com. Reason : 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials s5sm24549512wra.77 - gsmtp
14:58:30.009 INFO - zzz@gmail.com Blynk-app (iOS-22500) joined.
14:58:39.491 ERROR- Error sending email auth token to user : zzz@gmail.com. Error: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials f6sm10585680wrt.87 - gsmtp
15:01:19.703 ERROR- Error sending email auth token to user : zzz@gmail.com. Error: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials m26sm1514349wmg.13 - gsmtp
15:04:53.688 ERROR- Error sending email auth token to user : zzz@gmail.com. Error: Couldn't connect to host, port: smtp.gmail.com, 587; timeout 30000
15:05:51.232 INFO - zzz@gmail.com Blynk-app (iOS-22500) joined.
15:06:07.650 INFO - Using data dir '/home/pi/Blynk'
15:06:09.911 INFO - Region : local. Host : eth0.
15:06:11.529 INFO - Initializing gmail smtp mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
15:06:11.627 INFO - Reports : 0
15:06:11.629 INFO - Didn't find custom user certificates.
15:06:11.633 INFO - Didn't find Let's Encrypt certificates.
15:06:11.633 WARN - You didn't specified 'server.host' or 'contact.email' properties in server.properties file. Automatic certificate generation is turned off. Please specify above properties for automatic certificates retrieval.
15:06:11.633 WARN - ATTENTION. Server certificate paths (cert : '/home/pi', key : '/home/pi') not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
15:06:14.077 INFO - HTTP API and WebSockets server listening at 8080 port.
15:06:14.081 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
15:06:14.082 INFO - Mqtt hardware server listening at 8440 port.
15:06:18.073 INFO - zzz@gmail.com Blynk-app (iOS-22500) joined.
15:06:35.884 ERROR- Error sending email auth token to user : zzz@gmail.com. Error: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials e6sm9734126wrt.14 - gsmtp
15:08:17.612 ERROR- Error sending email auth token to user : zzz@gmail.com. Error: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials b195sm5288014wmg.36 - gsmtp
15:11:29.809 WARN - User 'admin@blynk.com' not registered. /192.168.1.62:59796
15:11:43.014 INFO - admin@blynk.cc Blynk-app (iOS-22500) joined.
15:11:58.449 INFO - Creating new dashboard.
15:11:58.985 ERROR- Error sending email auth token to user : admin@blynk.cc. Error: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials g2sm1569175wrh.7 - gsmtp
15:12:07.016 ERROR- Error sending email auth token to user : admin@blynk.cc. Error: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials a14sm11164967wrx.96 - gsmtp
15:12:43.213 INFO - zzz@gmail.com Blynk-app (iOS-22500) joined.
15:14:12.703 ERROR- Error sending email auth token to user : zzz@gmail.com. Error: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials 11sm2453004wmg.27 - gsmtp
15:17:43.477 ERROR- Error sending email auth token to user : zzz@gmail.com. Error: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials c12sm10804469wrt.68 - gsmtp
15:18:06.608 INFO - Using data dir '/home/pi/Blynk'
15:18:08.756 INFO - Region : local. Host : eth0.
15:18:10.360 INFO - Initializing gmail smtp mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
15:18:10.457 INFO - Reports : 0
15:18:10.458 INFO - Didn't find custom user certificates.
15:18:10.462 INFO - Didn't find Let's Encrypt certificates.
15:18:10.463 WARN - You didn't specified 'server.host' or 'contact.email' properties in server.properties file. Automatic certificate generation is turned off. Please specify above properties for automatic certificates retrieval.
15:18:10.463 WARN - ATTENTION. Server certificate paths (cert : '/home/pi', key : '/home/pi') not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
15:18:11.899 INFO - HTTP API and WebSockets server listening at 8080 port.
15:18:11.903 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
15:18:11.905 INFO - Mqtt hardware server listening at 8440 port.
15:19:09.064 INFO - zzz@gmail.com Blynk-app (iOS-22500) joined.
15:19:15.630 ERROR- Error sending email auth token to user : zzz@gmail.com. Error: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials g81sm3582984wmf.7 - gsmtp
15:19:53.027 ERROR- Error sending email auth token to user : zzz@gmail.com. Error: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials c21sm13414631wre.35 - gsmtp
15:29:29.731 INFO - zzz@gmail.com Blynk-app (iOS-22500) joined.
15:29:31.469 ERROR- Error sending email auth token to user : zzz@gmail.com. Error: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials d2sm10448757wrq.94 - gsmtp
15:29:51.683 INFO - Using data dir '/home/pi/Blynk'
15:29:53.809 INFO - Region : local. Host : eth0.
15:29:55.445 INFO - Initializing gmail smtp mail transport. Username : example@gmail.com. SMTP host : smtp.gmail.com:587
15:29:55.554 INFO - Reports : 0
15:29:55.555 INFO - Didn't find custom user certificates.
15:29:55.559 INFO - Didn't find Let's Encrypt certificates.
15:29:55.559 WARN - You didn't specified 'server.host' or 'contact.email' properties in server.properties file. Automatic certificate generation is turned off. Please specify above properties for automatic certificates retrieval.
15:29:55.560 WARN - ATTENTION. Server certificate paths (cert : '/home/pi', key : '/home/pi') not valid. Using embedded server certs and one way ssl. This is not secure. Please replace it with your own certs.
15:29:57.016 INFO - HTTP API and WebSockets server listening at 8080 port.
15:29:57.021 INFO - HTTPS API, WebSockets and Admin page server listening at 9443 port.
15:29:57.022 INFO - Mqtt hardware server listening at 8440 port.
15:32:18.958 INFO - zzz@gmail.com Blynk-app (iOS-22500) joined.
15:32:21.217 ERROR- Error sending email auth token to user : zzz@gmail.com. Error: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials m189sm2260292wmf.7 - gsmtp
15:39:11.221 ERROR- Error sending email auth token to user : zzz@gmail.com. Error: 535-5.7.8 Username and Password not accepted. Learn more at
535 5.7.8 https://support.google.com/mail/?p=BadCredentials e12sm10292010wrs.91 - gsmtp
"I don’t have a server.properties file as I’m not sure if I need it/what to do."
